08-25-2020, 07:39 AM | #1 |
Carpe manana
Positraction OEM rear axle? What’s on your differential?
Can anyone shed light on what tag and fitting were used on the 1/2 ton rear differential for positraction equipped trucks? Innie or outie style fitting?
Thanks.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-25-2020, 08:35 AM | #2 |
Re: Positraction OEM rear axle? What’s on your differential?
Outie on this 67 short bed .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-25-2020, 08:37 AM | #3 |
No picture but my old '72 Blazer was posi and had an innie.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
08-25-2020, 10:45 AM | #4 |
My '68 has the tag and outie style plug. Same as Grumpy's photo. I thought it was kinda strange b/c the truck is a bare bones build with 6 cylinder and 3 on the tree. But I did a rear axle swap and confirmed it's definitely a posi.
08-26-2020, 07:00 PM | #5 |
On the 5 camaros I had 69 and 70 had the outie and the 71 and 72 had innie
08-27-2020, 04:04 PM | #6 |
Carpe manana
Thanks for posting - maybe a switch for 71-72 axles?
If I recall, the fitting threads differ between posi and non-posi rear ends.
09-01-2020, 08:43 PM | #7 |
Threads on both are 1/2 pipe thread
09-01-2020, 11:42 PM | #8 |
I always thought that type of lube tag was dealer installed. Some ratio tags and lube tags were installed by manufactures like Spicer(spicer lube tags are bolted to the cover like a ratio tag) But dealer could still put a ratio or lube tag on an axle. I think if you have a red plug lube tag it's appropriate to put it on "any" car or truck needing posi warning.
2 cents j
White K20 |
09-02-2020, 08:35 PM | #9 |
Carpe manana
The parts manual lists a filler part number for 71-72 posi applications. I’m still chasing this down.
03-25-2021, 08:16 PM | #10 |
Carpe manana
I’ve tracked down what I’m thinking is the correct hole plug and tag for the 1/2t posi rear in 72. The plug is a mushroom shape with an “innie” recess for a socket. Note the tag says limited slip not positraction.
A GM piece (right) next to a reproduction. The GM plug is an earlier year “outie” style.
