Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-27-2020, 12:43 PM   #1
wbmoore
‘79 C70 front bodywork on to a ‘77 C30 crew cab
Does anyone have firsthand knowledge of installing a 1979 C/70 front clip on to a 1977 C/30 crew cab body ??? There are many internet photos of this combination on C/70 chassis and even some that appeared to be on C/30 frames. I know some of these were made for railroad companies, etc.... were these after market or GM factory built ???
Not wondering about the frame fitment ....just wondering about the front clip to the crew cab problems.
Per usual, answers saying Can Do and No Way are easily found on the InterWeb.
Thanks.
1967 GMC 3500 lwb dump flatbed project
1969 GMC 2500
1979 GMC 7000 fire crew truck w/water pumps
1982 C/30 Cummins NV5600 Crew Cab project
wbmoore is offline   Reply With Quote
Old 08-27-2020, 04:59 PM   #2
txagincali
Re: ‘79 C70 front bodywork on to a ‘77 C30 crew cab
I don't have any firsthand knowledge on these but have some experience on the 67-72 style which may or may not directly translate to the 73+ body styles.
The short answer is yes they can fit and should bolt in no problem at least cowl to fender-wise just fine.
The big issue you are going to run into is with grafting the medium duty front end to the light duty body (assuming you are using the light duty chassis) is that the medium duty fenders and hood are significantly shorter than the light duty parts. There would be a need for significant fabricating to make it fit/let alone lining up the wheel in the wheel well.
A smaller issue, but an issue nonetheless, is that the fenders and fender extensions cut into the lower corner of the door. This is in part to make way for the larger wheel/tires but also the inner fenders connect underneath the kick panels and actually cut into the firewall some for clearance. Now with those pics you posted, they don't look to be AS bad as the 67-72 but still something you should think about when going in.
Are you running the C30 frame and wanting to just install the C70 nose? Or are you swapping the C30 crew cab body onto the C70 frame?
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint)
1969 GMC C10 Pickup SWB Stepside (heart transplant)
1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts)
1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts)
txagincali is offline   Reply With Quote
Old 08-27-2020, 09:10 PM   #3
wbmoore
Here’s the deal: I have a 1982 2WD C/30 crew cab frame and a 1977 crew cab body. I’m installing a Cummins 12v w/NV5600 in it. It’s being built to tow a fifth-wheel. It might be easier to lift the body rather than cut the firewall/trans cover. If I lift the body, it would be appropriate to add the C/70 front clip if the 12v will fit. I just bought the C7000 fire truck above for the water pumps .....so the bodywork could be used on the crew cab. I could possibly use the C70 frame (haven’t measured it yet) except the insurance might be a bunch higher.
1969 GMC 2500
Old 08-30-2020, 01:35 AM   #4
jumpsoffrock
Not that it's any of my business but will it pass smog?
Very interesting build nonetheless.
jumpsoffrock is online now   Reply With Quote
Old 08-30-2020, 09:38 PM   #5
wbmoore
....jumps off rocks: the 1982 C/30 frame was originally a GM 6.2 diesel so should be okay.
Has anyone put a C7000 front clip on a C/30 cab ???
1969 GMC 2500
Old 08-31-2020, 07:12 PM   #6
txagincali
I think you would be better off keeping the C70 chassis and front clip and swapping the crew cab body onto it. The front body mounts will line right up, the rears will just have to be fabricated. Then you know the front end will mate up and you won't have to mess with wheel alignment in the wheel well. But you'd be stuck with the weight and HD axles that probably won't go too quickly.
If you put the C70 front clip on a C30 chassis, you will have 4-6 inches of frame sticking out in front of the grille. then you'd have to move everything back (axle, spring perches, steering etc.) Check out the Duke by RTech. He managed to squeeze a 12v Cummins into the engine bay of a C50 but I think a decent amount of fab work was needed since you are shortening the space it can fit with shorter fenders and bigger rad.
