08-28-2020, 07:29 AM | #1 |
Recommendations for stock replacement V30 Springs
I'm looking to replace the front springs on my 89 V30. They're sagged out pretty bad. Who do you guys recommend for the best stock height replacements? I found these. Any thoughts? Thank you!
https://www.generalspringkc.com/product_p/22-464.htm
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
08-28-2020, 12:22 PM | #2 |
Re: Recommendations for stock replacement V30 Springs
Yup!! go for it, or find a local spring/truck shop that can rebuild what you have
08-29-2020, 03:55 PM | #3 |
I used general spring and replaced both front and rear. You can see photos here.
http://67-72chevytrucks.com/vboard/s...d.php?t=599593 |
08-30-2020, 10:38 AM | #4 |
i am also getting ready to swap in front springs . but with the fisher snow plow i run ( heavy ) i will be doing the upgraded 4 leaf option from the aftermarket .
unless you pay good money for DAYTON or TRIANGLE spring brands then its random spring brand from us / canada / india type places . i already have 22-547 rear in the 2,600 lb capacity over the stock 1ton rears weight . then i put in timbren bump stops for the extra when needed .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-02-2020, 09:45 PM | #5 |
E.H.F.D Engine #2
I just replaced the sagged front springs in my 89 V3500 also. I got mine from general spring, I went with the 4 leaf 1900lb springs. They Brought the height back up to where it should be. I haven’t had time to get it out and see what they ride like but I’m expecting pretty stiff! Highly recommend general spring.
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
09-02-2020, 11:38 PM | #6 |
I did the Dayton/Stanley thing. 5 years now and no complaints.
http://67-72chevytrucks.com/vboard/s...d.php?t=643974
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
