Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-31-2020, 10:19 PM   #1
Det57
Front Brake Issue
I have a 69 C50 with power brakes (Booster under the cab and about 5 years old). My front brakes are locked up. I havent tackled it yet. I bought the truck several months ago and have been working on other things on it.
When I go to move it she's locked up in the front. Im thinking possibly collapsed brake hoses in the front or maybe rusted drums??. It does have a new single line master cylinder on the firewall replaced within the last year. This was an old tow truck, and I did check to make sure there was no front line lock on it.
Any other suggestions on what to look for that I may be missing on this old truck? Ive decided to sell it and want the brakes working properly.
Det57 is offline   Reply With Quote
Old 09-01-2020, 10:53 AM   #2
Bimus
Re: Front Brake Issue
I have had brakes stick when out of adjustment
Bimus is offline   Reply With Quote
Old 09-01-2020, 11:58 AM   #3
Det57
These are locked up pretty tight.....not even sure Ill be able to get the drums off....
Old 09-01-2020, 12:46 PM   #4
Bimus
Will the brakes release if you bleed them off at the wheel cylinder ?
Old 09-01-2020, 10:44 PM   #5
Det57
Im going to try that tomorrow.....
Old 09-03-2020, 07:34 PM   #6
Det57
Apparently a second type of master cylinder under the drivers side near the brake booster. Found the metal brake line that feeds the front brakes kinked badly in two places.....going to change it out tomorrow and see if that alleviates the issue. It may not be letting the brake fluid come back to the cylinder...
Old 09-09-2020, 01:53 PM   #7
rkn463
rkn463's Avatar
Try cracking the bleeder screws and see if fluid comes out as Bimus suggested, if no pressure there then you have some other problem. I've had drums rust to the brake shoes on more than one vehicle that sat too long and I assure you it is a pain to get them loose.
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 09-09-2020, 09:12 PM   #8
1976gmc20
I made a portable sawmill on an extended 2 ton truck frame using the front axle (hitch on the rear of the frame).
Anyway, I got it mostly together and went to move it and one tire just skidded. Put the biggest tip on a torch and heated the drum all the way around and it finally popped loose.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
