Old 09-09-2020, 09:34 AM   #1
1tuff71
1tuff71's Avatar
performance brakes
ok guys I'm thinking of going to a brake rotor/caliper upgrade on my 71 Blazer. has any one swapped to a wilwood or any other aftermarket set up you could suggest. I want to keep my current wheel/tire set up without any changes. thanks
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 09-09-2020, 10:02 AM   #2
SCOTI
SCOTI's Avatar
Re: performance brakes
What is your current wheel/tire set-up? That info could help you get more accurate/specific answers.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-09-2020, 03:04 PM   #3
1tuff71
1tuff71's Avatar
sorry. I am running 38" tires on 15x12 wheels and 9"of lift. I'd like to run a set of wilwood or ssbc rotors and dual piston calipers. stopping this beast is not ideal with the stock set up so looking to get some help with an up grade. thanks for any ideas or thoughts.
Old 09-09-2020, 04:03 PM   #4
Richard
Maybe consider going to hydro boost brakes. Will increase clamping force of your stock components. The aftermarket big brake and rotor set ups are great and definitely improve braking performance. The caveat with most though is you are tied to their rotors and pads. Brake job cost and parts availability is much better with stock parts. Knew a guy with a super nice Camaro and a Brembo kit. Even with normal driving required a brake job every 15-20k. If you want the aftermarket big brakes for looks as well. That is as good a reason as any to switch.
Richard
Old 09-09-2020, 04:41 PM   #5
SCOTI
SCOTI's Avatar
x2. Hydra-boost, 4-wheel discs (that fit within the 15" barrels), & the best pad material you can get for your application. Off the shelf brake pads are for stock stuff... You need pads from a manufacturer that offers more aggressive compounds.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-09-2020, 06:53 PM   #6
Ziegelsteinfaust
If you get the brackets you can use C10 front calipers on the rear with 11.75x1.25 rotors. Or 68 Corvette front rotor hats if your running 5 lugs. Or maybe you can redrill them too.
Also a larger bore master cylinder is a cheap alternative to hydroboost.
But honestly with 38's I would be looking at doing a 8 lug swap with 16" or larger rims. Because 15" rims really limit the possibilities of cheap readily available factory options. Plus they will last longer then more over worked 1/2 ton options.
Ziegelsteinfaust is offline   Reply With Quote
Old 09-10-2020, 11:51 AM   #7
tallwelder
I just received this email today, apparently this is new.? Wilwood has dropped spindles and front brakes to fit. I believe they have had rear brakes for Our trucks for quite some time.
https://www.wilwood.com/Media/Brakin...eid=00f0fc090d
tallwelder is offline   Reply With Quote
Old 09-17-2020, 05:39 PM   #8
1tuff71
1tuff71's Avatar
thanks guys.
Old 09-17-2020, 05:40 PM   #9
1tuff71
1tuff71's Avatar
thanks for the info guys. very helpful
