Old 09-13-2020, 12:25 PM   #1
DCLefler
cross member
Hi All
I have been doing a engine and transmission swap in my 65 SWB C10 (454 & turbo 350) and I am getting ready to install the engine and trans. The question is I have read that the cross member that supported the manual transmission/mount should be removed. Can anyone tell me if this true or point me in the right direction.
DCLefler is offline   Reply With Quote
Old 09-13-2020, 01:14 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: cross member
You should remove the cross member that was holding the transmission bell housing.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-13-2020, 01:43 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Re: cross member
Yes, when switching from a manual to an automatic, the manual trans mount crossmember needs to be removed. The auto won't fit with the crossmember still there
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-13-2020, 03:58 PM   #4
DCLefler
Re: cross member
Thank you for your help
454 swap, 65 c10, cross member, disc brake conversion, th350 installion
