09-17-2020, 08:24 PM | #1 |
Where foes this wire hook up or what is it for on brake prop valve
Can someone tell me dhat this wire does and where to hook it up or what to hook it to
Posted via Mobile Device |
09-17-2020, 08:48 PM | #2 |
Guest
Posts: n/a
Re: Where foes this wire hook up or what is it for on brake prop valve
That's the brake warning light in the dash. If you lose a brake line there is a piston in the proportioning valve that slides completes the circuit to ground and turns the light on in the bottom of the fuel gauge
09-17-2020, 09:45 PM | #3 |
i believe its a light brown or tan wire coming from the bulkhead connector
09-18-2020, 06:41 AM | #4 |
Thank you. Learn something every day. Appreciate the help.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=265847 |
09-18-2020, 09:24 AM | #5 |
09-18-2020, 10:19 AM | #6 |
You probably should ditch the brass combo valve. The brass ones are notorious for leaking under that rubber cap at the front.
72 C10 lwb fleetside -stock 350/350 combo |
