10-02-2020, 04:01 PM | #1 |
1971 k30 duramax/ZF6/np205 orange!!
So I traded for this pickup in 2010. I drove it around a few years before tearing into the rust repair project. Things quickly got out of hand with every aspect of the build. Since I started, I’ve built a house, had more kids, started a business, and built a shop.
The specs: 1971 K30 long bed original orange/white paint (Truck was 2wd originally) 2007 duramax engine with 42,000 miles ZF6 manual transmission with southbend super street clutch Custom billet adapter to NP205 GM Dana 60/14 bolt with 4:56 gears and rear locker (military truck doner) Custom 52” leaf springs with FGB52 kit from diy4x (10” lift total) Fully boxed frame with all custom tube crossmembers 44x18.50 ground hawgs on 16.5x14 weld sidewinders I just finished repainting the truck myself in the factory colors with SPI products I’ve spent so much time working on this thing. My goal is to reassemble it and drive it to Rod Run in Long Beach, Washington 2021.
'71 org/wht 3/4 ton 4x4 |
10-02-2020, 04:17 PM | #2 |
Re: 1971 k30 duramax/ZF6/np205 orange!!
I love it already and it's not even done! Keep up the great work and keep us posted.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
10-02-2020, 06:39 PM | #3 |
Moderator
Twin turbos?
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
10-02-2020, 06:50 PM | #4 |
SWB 4x4 Collector
Looking great, how did your engine crossmember turn out?
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-02-2020, 09:41 PM | #5 |
Yes it has an s475 over stock compound setup.
All the crossmembers are dom tubing. All the mounts are 2” dom sleeves with poly bushings and 5/8” bolts. The engine sits as far down and back as possible. The firewall has been completely redone to allow shoving the engine back.
10-03-2020, 06:42 AM | #6 |
Very nice truck! High quality
71 C10 72 K20 72 K10 Super Kirk |
10-03-2020, 05:19 PM | #7 |
Nice truck
How far back did you have to make space for the duramax ? I have added a k30 to my project build list only thing in my yard missing is a dana 60 front diff |
10-04-2020, 12:33 PM | #8 |
The couple that I’ve seen have the engine far enough forward to clear the stock down pipe. I recessed the center of the firewall and make the opening larger to clear the heads. Probably 6” recess and 3” total on each side wider. I further recessed a box to clear the hot side pipe leaving the stock turbo. There is no room inside the frame to run exhaust in the passenger side. The transfer case to frame rail clearance in a few inches. That’s why most guys run a ford high pinion Dana 60 to be drivers side drop. I didn’t want to do that. A classic Chevy is passenger drop. That’s why the exhaust is outside the frame. I had to notch the cab supports a bit to give clearance without the pipe showing under the truck. It will all be heat wrapped.
10-04-2020, 02:34 PM | #9 |
Nice lots of hard work
I agree keep it chevy diff Those dmax with zf6 stick shift trucks are fun to drive |
10-05-2020, 01:07 PM | #10 |
Amazing work! Look forward to seeing it done!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold) 1969 Jimmy, 2wd swapped. bagged, body dropped |
10-06-2020, 08:00 AM | #11 |
That's going to be a cool truck
NHRA Super Street 469C It only runs 10.90 at 156 mph |
10-06-2020, 08:33 AM | #12 |
All about them K’s
Nice work! That’s gonna be a beast. Are those real deal Hawgs or the interco remakes? Real deal hawgs are hard as hell to fine anymore. My dad had a set on a 71 K10 when I was kid. I love the look of them under these trucks.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
10-10-2020, 01:01 PM | #13 |
They are originals. Interco hasn’t made the Cobalts in 16.5.
