Old member
Is there a sticky for having the list of tools to do certain jobs on our truck?
I was just wondering if we had a place to put what we use to do work on the truck. Like I just pulled the cluster out of the ramp truck to see what had happen to the tach. It stopped working about month ago. Got it out and one of the studs is broken inside. I can pull it out but it's not hooked to anything it just spins. Here is what I used. Ratchet with extension and 1/2 socket. For loosening the column up. Pliers for the speedometer cable if its tight. Large Philips head screw driver for dash screws under the dash. Small Phillips head for cluster screws. Small flat blade for wiper knob. 8 mm wrench for factory oil line. Needle nose pliers for head light & wiper collar removal. Remember to disconnect the battery before you pull the head light switch out. Mine is a 10mm nut but the size will be different depending on the cable used. To get the cluster a part once out of the truck. 1/4 drive ratchet with extension and 1/4 socket for the outer screws and grounds. The back panels also. (note) You don't have to take the out screws out if removing the back panels, just the printed circuit so you can get to the 1/4" screws. Then a 5/16 socket for the nuts holding the printed circuit to the cluster. You have the twist lock bulb holders also. You have to be careful taking the instrument nuts loose. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 2009
Re: Tools for the job?
Great Idea
![]() I have often thought about a (must have) list of tools to keep in the truck while driving. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Old member
Thanks,
well this could be for that also. I didn't think about it on the road but it would be a good idea. ![]()
![]() Join Date: Feb 2009
Wiper arm remover/installer:https://shop.snapon.com/product/Wind...oval-Tool/A192
8" #1 Philips screw driver to remove an ashtray housing. These can come in handy: https://www.summitracing.com/parts/s...AaAk0jEALw_wcB
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Old member
Yes they are handy and I have both but not snap on brand.
