10-18-2020, 08:01 PM | #1 |
72 Cheynne SWB Wood Floor Help
Hi all, am looking for some help if any of you can be so kind Am lookig for a couple of pictures anyone might have that would show where the cross rails are located for a 72 SWB with a wood floor that is being installed new.
Any help would be apprieciated. Thanks |
10-19-2020, 08:19 AM | #2 |
laying low
Re: 72 Cheynne SWB Wood Floor Help
I pulled this diagram from the LMC online catalog that gives a pretty good idea of where they locate. The 1st, 2nd and 4th ones locate over frame mount holes. You can probably lay those out on your frame and figure the other 2 out.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-20-2020, 09:24 AM | #3 |
Hope this helps.
The left side of the pic is the back of the bed. The rear cross sill looks different because I had to modify it to accommodate the rear mounted gas tank. |
