Old 11-14-2020, 12:04 PM   #1
P-10Crew
Brake system for new build opinions
Truck: 53 AD, porterbuilt bagged, 9” big new style, 20x8.5 F 20x10R
I’m getting ready to spring for all the parts for the brake system on this build and would like some opinion’s and direction please.
If I ran 13” or 14” front rotors with 12” rear do those of you with experience think I could get away with running a non assist MC?
The reason I ask this is I would like to run the master cylinder under the floor to clean up the firewall. I have to run the Cpp modular or wilwood pro drop spindles. I have been looking at the wilwood 4 piston stuff but it’s at the top and possibly over the top of the budget. Cpp offers a decent looking front 13” kit but their rear kit for the 9” uses a completely different looking caliper.
Any ideas? TIA
P-10Crew is offline   Reply With Quote
Old 11-14-2020, 12:49 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Brake system for new build opinions
The master cylinder needs to match the caliper bore sizes not the rotor diameter. There is almost always more than one caliper that will work on any given rotor.
This web site should help explain
https://www.joesracing.com/master-cylinder-math/
RIP Bob Parks.
Old 11-14-2020, 02:55 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Brake system for new build opinions
My 2 cents, go as big as you can up front it does 95% of the stopping then just go with a normal size rear. Are something that looks close to the front.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-14-2020, 05:40 PM   #4
LS short box
I would give Tobin at Kore3.com a call. He sells brake kits from mild to wild. He can also spec out the MC that you will need.
If it's in the budget I would go 14" in front with your 20" wheels. The 14" rotors fill up the wheel quite nicely.
On my 68 C10 I'm running C5/C6 14" front brakes and 1997 Camaro 12" brakes in the back.
LS short box is offline   Reply With Quote
Old 11-14-2020, 09:58 PM   #5
xabichin67
Junior Member
X2 on Tobin at Kore3.
One of the most stand up and knowledgeable guy in the business.
No regrets on the many purchases I have made with Kore3
The older I get the less BS I have to put up with...….
xabichin67 is offline   Reply With Quote
