11-22-2020, 09:02 AM | #1 |
1979 C10 Scottsdale trim
I'm getting ready to repaint my 1979 Diesel (yes it still runs) Long Bed C10 with the Scottsdale side trim. I can see where mine goes from the faded paint-but it's long gone. I can't find reproduction side trim anywhere. Does it exist? Thanks
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
11-22-2020, 09:23 AM | #2 |
Re: 1979 C10 Scottsdale trim
Like this?
http://www.mar-k.com/Catalog/index.aspx
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
11-22-2020, 09:39 AM | #3 | |
11-22-2020, 09:33 PM | #4 |
If that the trim your looking for, it's after market or it the 81-87 black too way tape style Rubber/ Plastic Trim could be chrome or body color black textured. Chrome was the most seen. Check out 3M there is two other companies to see the option you can get
( body side trim two way tape.) OR E-bay, amazon, autobody supply shops, dealer, or dealer body shop.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
11-23-2020, 10:31 AM | #5 |
Spear points show up on eBay often. I believe that trim is available at most truck restoration catalogs as well.
11-24-2020, 07:22 PM | #6 |
This is as close as I could find. I found NOS ends on eBay fairly cheap. https://shop.advanceautoparts.com/p/...002/10596949-P
11-24-2020, 07:30 PM | #7 |
Are the rear ends in the picture the ones you found on EBay? What did you do for the front pointed end? Thanks for the help!
11-24-2020, 07:53 PM | #8 |
Just found square and spear ends NOS on EBay-Thanks for the tip!
