12-20-2020, 02:18 PM | #1 |
Weatherstrip and windows (front left and right including vents)
Whos got recommendations here .
SoftSeal , CCP, Steel Rubber , ebay specials .... so on .... Glue or no glue .... eg https://tinyurl.com/yc7kq2lx
FAKKY 57 PANEL BUILD Last edited by FAKKY; 12-20-2020 at 02:40 PM. |
12-20-2020, 03:43 PM | #2 |
Re: Weatherstrip and windows (front left and right including vents)
Don't skimp, you pay for what you get . short money garbage! Good money no problems with parts ,fit and work great Go with Steele Rubber and you will not have install problems.
12-20-2020, 04:58 PM | #3 |
I have used soffseal as replacement for new lmc rubber that was too hard to allow door to close properly after initial adjustments were done. old (new) seals were removed and soffseals installed in their place. no prob with soffseal closing on the same doors without any adjustments made.
doors should be adjusted without the seals so they fit the opening properly as far as gaps and height compared to surrounding sheet metal. then, the fenders get adjusted to fit the doors, hood etc. then when the door seals are installed, the seals should be able to squish out as required so doors don't need to be winched closed or be re-fit after new seals installed. |
12-20-2020, 06:14 PM | #4 |
Steele here.
12-20-2020, 06:44 PM | #5 |
So steele is out - I cant find it for less than 3x the price of others. Just cant justify it ....
Thinking https://www.summitracing.com/parts/pqp-dk-1110-55 Cant find much for our trucks but guys have been happy with company/products for other years
FAKKY 57 PANEL BUILD |
12-20-2020, 11:03 PM | #6 |
I can't speak to TF trucks, but I can say I've had perfect success with Precision seals in multiple places on my AD - windows, hood, etc. (I used generic door seals). They have the best installation videos on YouTube. And of course, Summit Racing's customer service is top-notch in every respect.
1951 Chevy Panel Truck |
12-21-2020, 10:33 AM | #7 | |
I want to do the front doors and the windows (and vent window). Assume this is everything ? For Beltline and so on. https://www.summitracing.com/parts/pqp-dk-1110-55 + https://www.summitracing.com/parts/mmp-wr2007
12-21-2020, 10:35 AM | #8 | |
good tips
12-21-2020, 11:45 AM | #9 | |
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
12-21-2020, 02:58 PM | #10 |
12-22-2020, 12:36 PM | #11 |
12-22-2020, 12:52 PM | #12 |
thanks zippi... all
12-22-2020, 02:58 PM | #13 |
The rod authority news letter has a write up on the Steele profiles.
12-26-2020, 09:57 PM | #14 |
