Old 02-01-2021, 11:40 AM   #1
C10_ForDad
1970 C10 Laying Frame with Trailing Arms and mounting my bags
Hi guys, so I picked up a frame to work on and get all cleaned and prepped to swap my cab and drivetrain over too. I figured on the front end I'll go with a Porterbuilt Stage 3 so I can lay frame. For the rear I can't really afford to go 4 link or with the Stage 3 from Porterbuilt. I was thinking of just running a bigger notch to clear the trailing arms or notching the frame where they contact. Does anyone have pictures of that? And I was also looking at where to mount my bags. I see tons of rides with them moved forward on the trailing arms, I don't mind doing that either but I also see KP has a set of mounts that's weld onto the rear end. Would that be more beneficial to have my bags inboard and on the axle?
C10_ForDad is offline   Reply With Quote
Old 02-02-2021, 05:22 PM   #2
C10_ForDad
Re: 1970 C10 Laying Frame with Trailing Arms and mounting my bags
Bump... Anyone?
I was researching and looking, I'm thinking I'd mount my bags inboard on the axle with a bridge for the upper mounts, and install the rears on a rear bridge rail behind the axle, or move them outside the frame rails so I'd have space for a watts link. Does this sound like a realistic setup for laying frame? I'm going to have my notch long enough to clear the frame
Old 02-02-2021, 09:51 PM   #3
PGSigns
PGSigns's Avatar
You can look at the stuff from chopping block on Pro performance (a vendor here) as an option and for design ideas for the back. I would build trailing arms with out the tip in the back that the stock arms have. Then flip the front brackets to help the geometry. Having the bags back by the axles is best.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-03-2021, 11:20 AM   #4
SCOTI
SCOTI's Avatar
Factory T/A's w/the front mounts flipped 180° & bags mounted on top of the rear end housing w/a bridge connected to the stepped frame section would work. A Watts or Panhard bar will work for centering. The Watts is more work but will help keep it centered better.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
