Tire size to run
As I am nearing the end of my resto project on my 70 C10 I am trying to decide on a tire size. My truck is lowered with 2.5 inch drop spindles in front and 4 inch drop springs in the rear. I will be running the 6 lug 15x8 rally wheels. I see people say they are running 275/60/15 but wouldn't that be too low profile. Maybe not but I need recommendations. The wheels are being refinished as we speak and as soon as they are done I'm getting tires. Thanks!
![]() Join Date: Dec 2013
Re: Tire size to run
I wanted a 29" tire so I ended up with the BF Goodrich T/As 255 x 70 x 15s on 8" rallys. I plan on driving the wheels off this truck when it's done and I'm not about to carry around a spare and jack in a new wood bed with a rear tank , With AAA premium towing service and the readily available tire brand and size made these a good choice for me . The most it will ever carry again will be a beach chair and a cooler .
![]() I like the look of the 20's and fat tires but I don't like trying to find them on a Saturday let alone replace a custom wheel and tire for $500 ++ out here in the country . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I have been having the same debate with myself. Here are the tire sizes available in 15". In my case I am going with the largest tire diameter I can get due to 3.73 gears and a TH350 transmission. 265/75/15 which is basically a 30" tire. The only problem is there are limited 30-31" tires that are not mud grips or off road tread. And I want it to look like a slightly lowered street truck.
It really depends on what you are trying to do. I would first consider your drivetrain and figure out the diameter first. Then check that that style of tire is available. https://www.tirerack.com/tires/sizes...sp?diameter=15 |
BlahBlahBlah
Here is a 15 inch only tire thread I started awhile back. Lots of good info there. There is also a link to another older yet thread in there.
http://67-72chevytrucks.com/vboard/s...d.php?t=703601
#5 | |
#6 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03,
Here is my truck with the exact same drop and exact same wheels you mentioned. I just got tires on it two weeks ago. These are 255/70-15. If I'd have gone another inch in drop all the way around the 60 series might be OK. I have a fifth rally wheel that I have primed and plan on painting solid black to use as a spare.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#8 | |
03,
Very nice looking truck. Set of rallys with some nice tires will make that ride look even better. I see you have inner fenders out of yours as well. Did you have to replace the passengers side? If so, did you go repop? I have to find a good inner for the passenger side and have not made up my mind which way to go yet.
#10 | |
![]() https://www.summitracing.com/parts/gmk-4143-350-67l https://www.summitracing.com/parts/gmk-4143-350-67r auto metal direct $78.99 + https://www.summitracing.com/parts/amd-250-4067-r
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-08-2021 at 06:56 PM. |
#11 | |
Same drop as yours 285-70-15 on rear, 255-70-15 on front
Fuzzy |
#13 |
Beep! Beep!
Are those really 70 series?
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
#14 |
Yes they are from coker tire Silvertown blackwalls
https://www.cokertire.com/tires/285-...blackwall.html
Fuzzy Last edited by hayhauler71; 02-11-2021 at 09:45 PM. |
#15 |
I am going to buy the size this truck has. I will get the cooper cobra 255 70 15 for the front and get cooper evolution ht 265 75 15 for the rear.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
#16 |
I'm going to got 255/70. I'm not interested in doing a stagger. I already have to deal with that with my corvette. 335's in the rear and 285' up front.
#17 |
![]() Join Date: Jul 2018
I am running the 6.5” van Rally wheels up front with 225/70-15 and 8” Rally’s in the rear with 275/60-15. I went with the Cooper Cobras. I have CPP modular drop spindles ( 2 or 2 1/2” depending what source you believe) with 1” drop springs, and waiting on my 5” drop coils from GMCPauls to come in.
1971 Custom/10 - 350/3 speed, Orange/White roof |
#18 | |
#19 |
I hate to post it because it looks like a cat in heat right now, but this is before I get back and can put the 5 springs in.
#20 | |
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 02-14-2021 at 06:37 PM. |
#21 |
275/60/15 T/A's all the way around. NO RUBBIN'.
2.5" spindles w/1 coil cut on the front. 4" springs, w/a 1" block, adj. track bar, shock relocate kit on the rear.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
#22 | |
