Old 02-14-2021, 12:47 PM   #1
kennyhammond
Steering box 2002 z71
Well have a lot of play in the steering and all joints look good and tight the box has slip. Is it the adjustment on the box I should do or just replace with a new steering box
kennyhammond is offline   Reply With Quote
Old 02-16-2021, 02:21 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: Steering box 2002 z71
If you have a lot of slop in the box it's worn.
I assume you have 1/8 or more of a turn before the movement of the steering wheel translates to movement of the pitman arm.
Adjusting the Saginaw power steering boxes generally doesn't compensate for the wear issue. You can try it but don't get your hopes up.
If you have a bunch of wear adjustment makes steering stiff at the ends of the travel and still loose in the middle where most of the wear happened.
If you have a rack & pinion setup you'll have to replace the steering rack.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-20-2021, 10:06 AM   #3
kennyhammond
Awesome. Thank you sort of what I was thinking but wanted to make sure
Old 02-20-2021, 01:26 PM   #4
hatzie
Moderator
hatzie's Avatar
Before you condemn the steering box make darn sure that's the problem.
Check the intermediate steering shaft between the rack/box and the base of the column at the firewall for loose joints.
Check all of the steering linkage joints for wear. Tie rod ends, pitman arm, idler arm, Upper & Lower ball joints, and A-Arm bushings.
Check the wheel bearings too.
