tail light one side is dim
Just installed my AAW harness and new tail lights and the right side is dimmer then the left for the brake /turn/flasher
I switched out the bulb and touched a ground to the housing and to the frame with no change Everything else has worked flawless through out the complete harness. Any suggestions ? |
![]() Join Date: Mar 2003
Re: tail light one side is dim
It's obviously a voltage drop.... caused by a connection not crimped correctly, connector not plugged together tight or a loose ground. Have somebody stand back there while you wiggle/squeeze harness' and connectors.
![]() Join Date: Jan 2001
Make sure your jumper is connected to a good ground, and touch it to the rim on the base of the bulb itself. My bet is your ground is the problem.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Nov 2018
Quick test for a grounding problem is put a jumper wire from your battery ground post to the weak tail light ground.
![]() Join Date: Aug 2019
When testing I always ground at the battery.
sounds like a ground problem
#7 | |
Old member
![]() Quote:
What about the tail lights? They are the other element in the bulb. How do they compare? If they are brighter I bet money you have crossed the wires up. The brake lights and turn signals use the same element. Are you may have the wrong bulb. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
There is no ground wire on the harness back there so I am assuming it is grounded by how the housing mounts.
Tail light fixtures are new. instructions did not show hooking up a ground other then on the side markers that I am not using. Tail lights to me look like the same brightness on both sides. I will check the harness wires and try a ground from the battery. |
#9 | |
Old member
![]() Quote:
I have even seen people drill a small hole in the bottom of the housing and put a long screw in it with a ground wire running to the frame for better grounding. ![]()
Post Whore
![]() Join Date: Feb 2016
Is my brother riding on that side of the truck?
![]() Did you verify both bulbs are the correct ones? There are dual filament bulbs that are the brightness on both filaments.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() ![]() Join Date: Jan 2005
Swapping the bulbs left to right would help identify if there is an issue with the bulbs if the issue moves to the other side along with the bulb.
That is what I meant about switching the bulbs, I switched the left and right bulbs with no difference.
I will be running some tests this weekend. Thank you everyone for the suggestions. |
#13 |
At this point you need to check the voltage on the green wire at the bulb (remove bulb ) and compare it to bat voltage.
#14 |
![]() Join Date: Jun 2014
I just did installation of the AAW harness on my truck and did the same thing.. dim tail lights/brake lights. I did what others suggested and ran a wire from the battery to the tail light to check the ground. That was the issue... poor ground (just had the truck painted). Mine is a stepside, so I just ran a ground wire from the light down to the frame and problem was solved.
#15 |
![]() Join Date: Jul 2015
If FB's solution does not solve it, do the voltage test and look next at the turn signal switch and all those little connections in the dash.
That half moon steering column connector would be suspect to me also. |
#16 |
First check the ground.
Then If that doesn’t work check the ground again Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
#17 |
![]() Join Date: Feb 2004
I have seen brand new turn signal switches be bad. Lots of moving parts and the little metal tabs inside sometimes bend and dont make perfect connection
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#18 |
I ran extra grounds from the frame to the taillight housings too. I read somewhere that dealers/shops would often do this on new trucks to fix intermittent brake & taillight issues.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 02-19-2021 at 09:06 AM. |
#19 |
Old member
Horse shoe connector may not be making good connection. I had this problem with my Ramp truck when I installed the tilt steering column. The pins would push out of it but not enough to show. Pull and tug on it make sure you have good connections with a test light starting there and work your way back to the light at each connection until you find the bad spot.
#20 |
I got it fixed and yup it was the ground.
Thank you all. |
#21 |
I am late to the party but glad you got this fixed.
68' with no bells or whistles unless I add'em. |
#22 |
#23 |
#24 |
Best advise I ever got when I started restoring classic cars/trucks regarding electrical issues.
“First check the ground. Then If that doesn’t work check the ground again” Mark Posted via Mobile Device |
