'71 402 engine questions
I have a 1971 C20 with a stock 402 motor. I had planned on buying one of the Edelbrock top end kits that comes with the aluminum heads, camshaft, intake lifters and other required trinkets to do the job. I called last week to order the parts... I have been procrastinating for a year to order. I learned that I had two things against me at this point. First is Edelbrock is relocating their manufacturing facility and second apparently covid had caused them to fall behind. I was told that the earliest I could expect delivery is May 15th. I of course have time and want to do it now. If I don't do this project now I won't get to it for two more years. I will be building a new house and shop that will eat up my time.
All that I am looking to accomplish is to add a little pep to this way under powered motor. I don't know the history of the motor but the engine is healthy, it burns no oil, has good compression, no smoke etc. I have been driving it for 5 years now and it's reliable and sound. I had planned to pull the engine and disassemble, clean up and assess where to go from there as to whether it needed further machine work etc. Now that I can't get my parts and I don't really want to wait I am looking for ideas. I am thinking of just doing the cam, lifters, rockers, intake because I can find these items individually, there are no heads available. I have built many SBC for my own race cars but never have even opened up a BBC. I am seeing the term oval, peanut and square port terms being thrown around with regards to head and intake runners. What did these trucks come with? Is the only way to know for sure to get casting numbers or pull it apart? I have done an in the truck cam swap a couple of times in a square body truck for buddies of mine years ago. How big of a PIA is it on one of these? AM I still better off to just pull the engine? Thanks in advance... |
Who Changed This?
![]() Join Date: Jan 2013
Re: '71 402 engine questions
I got nothing on the hot dog add-on parts, mine is bone stock except for a bore job and "RV" cam. From what I see, you could just wait two years. Mine loses water and oil with nothing on the ground, so I know I'm going to have to do something about it someday. How weak is it?
![]() Join Date: Jun 2005
The heads will be oval port. You you can put a pretty big cam in without worrying about piston to valve clearance. I have a .501/.527 lift cam and had the heads milled .020” and I checked it with modeling clay and still had over .100” clearance. The engine is low compression due to the large chamber heads so milling them along with a decent cam will help with compression.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Stock heads make great hp if you do them right .
Who Changed This?
OK, how much HP are roller rockers worth? Is there something else there that I am missing?
#6 | |
Also has a roller cam What I'm saying is stock heads done right make big hp no need for aluminum heads in a car/truck that 100lbs could make or break it in the 1/4 mile The engine in my chevelle
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 02-21-2021 at 12:09 AM. |
#7 | |
Like I said the motor is healthy but just seems wimpy. It gets up and goes and pulls okay but anything beyond half throttle all it does is make more noise and doesn't go much faster. As I understand it the big blocks in these truck were severely under cammed and the intakes don't flow every well. I am not looking to build monster HP but I want just a little more snort. I know that stock iron heads can be done up to build big HP. My thoughts were by the time I do a valve job with new guides, seats, valves, locks, retainers, seals, and the corresponding machining I will have almost the same money as a set of new aluminum heads that come assembled.
What are some good camshafts to research to accomplish my goals? Thoughts on doing the cam swap in the truck? |
OP - when you try to get more power out of an engine by installing high-flowing heads or a bigger cam, you move the powerband up and can actually lose low-end power.
If you really need more power, consider a 454 or 496 build instead of modifying your 402. I don’t think you’ll be thrilled with the outcome. For instance, you might find the engine wants to stall in gear because of the bigger cam with the stock converter, or you need to set the idle really high to stop that from happening, etc. |
A hydraulic roller retrofit with a mild cam could give you some more power everywhere and improve drivability. If you don’t want to replace the engine completely, that’s probably a better bet IMO.
As I said I have a roller cam in it if you look at my quote you posted. My stock engines of that era have flat tappets. Even my supercharged Studebaker. As does my AMX pulled the motor as it was easier to change out the trans that I blew first gear. Yup rare group 19 parts . The 390 engine is worth more than most of my cars or trucks
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 02-21-2021 at 12:57 AM. |
i was just trying to clarify because you were responding to a question about roller rockers and i didn’t want anyone to misunderstand and think that putting roller rockers on their flat tappet mean they could stop worrying about zddp.
#13 |
K . But I dont think any reputable builder would put roller rockers on a flat tappet cam .
#14 | |
#15 |
#16 | |
We’re talking bout a street engine not a 800 and up track engine that the power comes on a 5grand
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 02-21-2021 at 01:30 AM. |
#17 | |
i don’t think the cam and lifter care whether there is a roller rocker or a stamped stock-style rocker at the end of the pushrod? it’s not like it puts more pressure on the cam/lifter interface, that’s dictated by the valve spring pressure. |
#18 |
Once you start changing the ratio you put more pressure on the tappets and the cam just by compression of the spring. On a mild engine it may work for 50 thousand miles. In my experience it’s better to make the whole valve train up to the task
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 02-21-2021 at 01:45 AM. |
#19 |
ok so assume you replace 1.5 stamped rockers with 1.5 roller rockers and change nothing else. how is this going to hurt the cam or lifter?
#20 | |
Your statement was to adjust the the ratio higher on the rockers .stock to stock ratio your wasting money keep the stamps
#21 | |
sorry bud - you are dead wrong in both posts. |
#22 | |
Really never said roller rockers cant be used with flat tappets but why would you ? 13 stands as written a reputable builder making a scratch engine wont put a roller rocker on a flat tapet engine , the cam would have roller lifters
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 02-21-2021 at 08:09 AM. |
#23 |
anyway - roller rockers are fine on a flat tappet, but you still need to think about zddp levels unless you switch to a roller cam.
#24 |
here is a link to a flat tappet build with roller rockers:
https://www.hotrod.com/articles/ccrp...que-383-build/ |
#25 |
I am glad that we got that straitened out. I guess I don't understand what all of the squabbling was about. I never asked anything about roller rockers or flat tappet cams. I do know when I was building engines more frequently I always used flat tappet cams, some with hydraulic lifters and some solid lifters. Almost always used some type of roller tip rocker or full rolling fulcrum rocker arms. The hype then was that it reduced oil temperature and valve train wear. It also seemed to make a tick smoother power. I guess I wouldn't hesitate to do it again. I never had a bad result on account of it.
