Junior Member
![]() Join Date: Dec 2020
Jack stand placement
I know this is trivial. Does anyone see issues with having jack stand placed at the very front of the frame rail? I used to always put them directly under the firewall, but never liked the way the front end sagged. Any input would great, thank you.
Posted via Mobile Device |
Re: Jack stand placement
I've always put the stands under the lower control arm. Weight is on the suspension
![]() Join Date: Dec 2009
A member on the board made these in picture below.
Great Idea ![]() Here is a set that could be purchased (Link Below). They are 5 lug Universal 5-slot pattern fits 5 x 4 1/2 through 5 x 5 wheel stud patterns. Set of two, requires 2 Auto Dolly platforms (sold separately). Use them on just one end of the car or buy 2 sets to cover all four corners. Link: https://www.pegasusautoracing.com/pr...asp?RecID=9835 .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#4 | |
Junior Member
Super cool wheel stands. I just went back to wheels and tires for now, probably a little preemptive on the stands. I imagine anything will be good once the engine is out Last edited by 71step35035012C10S; 02-21-2021 at 10:25 PM. |
![]() Join Date: Jan 2001
I always place them under the axles if that's an option. Otherwise I place them on the frame as close as possible to the axles. If the rear of the truck can't move, I don't see a problem with where you have them.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
I usually put them on the frame behind the front suspension. The same place the front arms of a 2 post lift would go.
Insert clever text here: |
![]() Join Date: Mar 2003
Depends on what I'm working on
![]() Join Date: Feb 2009
I've had stands further forward than the picture in the OP many times, drivetrain no body. But I support the engine crossmember at the same time. I don't see why there would be unnecessary strain on the frame rails so long as it's a good spot & not too far forward.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I'm not sure there's an issue putting the stands as shown in post one. I usually put them inside the drums on a diff, and under the shock mounts on the LCA, or as near to the tire frame load as practical, if any of that makes sense...
![]() Join Date: Apr 2009
In 40 Years Working on Trucks Cats always on Axles And Under AArms,
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
![]() Join Date: Aug 2019
I like the looks of the jack stands that bolt to the drums/rotors. I'm going to make me some.
Depends on what I am working on. But mostly I use the rear axle or front cross member. I don't like to use the front control arms as I have had a few occasions where they slipped some when putting the truck weight on them.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
