02-27-2021, 10:18 AM | #1 |
Need help with glove box hinge
I'm starting to put my truck together and I am having a hard time figuring out how the glove box hinge is supposed to go on. The wire spring doesn't provide any tension when the door is closed. I put a couple of pictures of it here. Is the wire supposed to go on the outside so it pushes out on the door when it's closed?
Thanks in advance!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
02-27-2021, 10:23 AM | #2 |
BlahBlahBlah
Re: Need help with glove box hinge
Here is a pic of my 71
Much larger pic here .... http://67-72chevytrucks.com/gallery/...hp?photo=47452
02-27-2021, 03:36 PM | #3 |
My '71...
02-27-2021, 05:37 PM | #4 |
Thank you both. That helps.
03-07-2021, 10:44 AM | #5 |
Thank you guys. I got the glove box door mounted today and it works great!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 03-07-2021 at 02:09 PM. |
03-07-2021, 11:28 AM | #6 |
One of those little things that make you smile when its done. Cheers!
03-07-2021, 03:38 PM | #7 |
Yes, and I was worried about painted parts sitting around and getting damaged.
