![]() Join Date: Oct 2009
Header help.
I know this has been discussed here in years past but I've never seen a definitive answer. I have a 68 c10,going with a 454. I want to keep headers up,running alongside the inside frame rails. I can't stand to see headers hanging down low. Anyone recommend a brand or application that will do this?
![]() Join Date: Jun 2005
Re: Header help.
I used Hedmans for ‘68-72 Chevelle. Fit perfectly, but had to do away with the stock shift linkage. You want to get the ball and socket type, mine are 68190. My build is on a budget so I didn’t go with the coated ones. Hope this helps.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Re: Header help.
Also you will need to replace the stock trans crossmember with a tubular type, and drill holes in the trailing arm crossmember for the pipes to pass through.
![]() Join Date: Jan 2021
I used Doug’s headers, not Doug Thorley. My good friend has a’68 with a 454 and we installed Doug’s headers probably 4 years ago. They fit very well, don’t leak and still look very good. And I know what will be going on my truck. Thanks
Posted via Mobile Device |
![]() Join Date: Sep 2019
Re: Header help.
I can help! I spent hours upon hours researching this topic. You really need to know which heads you have to establish what header to use. Hedman would not work on my promaxx aluminum heads for my 383 stroker (according to promaxx themselves). In the end I concluded the best fit and performance would be Doug Thorely's D371 Tri-y's. No need to cut the frame to fit and they do not sweep super low when viewing it from the side. They will also fit nicely through the frame. If you want a longer lower version you can get the D372-Y's. But I went with the snugger fit.
Re: Header help.
Hedman 68198 ( Chevelle full length elite ) fit good on my '67 with stock stands in the forward position, lokar cable tranny linkage. Did not have trouble with any clearance except for a small dimple required on the passenger side lower A-arm shaft nut. Tranny cross member was not a problem for me. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 03-03-2021 at 03:29 PM. |
![]() Join Date: Jul 2000
Re: Header help.
I have used Patriot headers, made with the same tooling as Dougs, but they are thinner gauge tubing (16 vs 14, as I recall). They tuck up very nice, much better than Hedman or Hooker.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#8 | |
Re: Header help.
