03-03-2021, 09:07 PM | #1 |
Hei Distributor
Hello I have a 71 chevy c10 with a 350 someone has put a hei dist in the truck prior to me owning it. Ever since ive owned I keep buring through ignition control modules every couple of months. Can any point me in the direction what is causing this please. I was told that the wire coming from the junction block to my distributor originally was a resistor wire needs to be changed over to run 12 volts at all times looks to be changed but am gonna do it again to make sure. Can i just splice as close to the junction block and as close to the connector on the distributor as possible and be safe?
Thanks for the help |
03-03-2021, 09:17 PM | #2 |
Re: Hei Distributor
Just run a new wire from the fuse block ,I would not tie into the resistance wire your asking for problems . When you change out module do you use heat sink paste on the bottom of module ?DO NOT USE DIE-ELECTRIC GREASE not the same as heat sink paste
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
03-03-2021, 10:14 PM | #3 |
Re: Hei Distributor
Here is how I replaced the resistor wire. https://67-72chevytrucks.com/vboard/...d.php?t=708975
03-03-2021, 10:36 PM | #4 | |
Re: Hei Distributor
Are you using heat sink compound under the module? Delco modules will last the longest. Some of the other aftermarket stuff is 3rd rate. My 69 one ton came to me hooked up to the resistor wire. It never killed a module in all the years it was like that. I did hook it to full voltage myself.
Saskatoon, Saskatchewan Canada |
03-03-2021, 11:01 PM | #5 |
Re: Hei Distributor
Make sure the coil has the ground strap or ground wire going from the center of the 3 wire connector to the coil. They seem to disappear when people change distributor caps. I do not have a pic, but I bet somebody will throw one up
03-03-2021, 11:25 PM | #6 |
Re: Hei Distributor
I had this problem. Pull the dizzy and check the end play and any other specs you can find. Mine was an old ACDelco and it was so worn out. To rebuild it with Echlin parts was going to be $200, so I bought, as a temporary fix, a Chairman Mao special on Amazon for $54 and haven’t looked back. I’ve put ~1,000 miles on it and I’m not having issues anymore.
There are a lot of reasons your module could be burning up. It’s not just the wiring, heat sink compound, hot engine bay, etc. The module is the weak link in the system, so you never know until you check EVERYTHING.
1968 GMC C2500 Long Bed Fleetside |
03-04-2021, 11:24 AM | #7 |
Re: Hei Distributor
Another thing to check is your coil. The epoxy they're set in doesn't dissipate heat, it holds it in. This can cause layer shorting in the coil, which takes out modules.
72 C10 lwb fleetside -stock 350/350 combo |
03-04-2021, 09:34 PM | #8 |
Re: Hei Distributor
So I tested my wire coming from my junction block on the firewall im getting 11.90 volts thru it. It is a 14 gage wire. Do I need exactly 12 volts or is that about what I'm gonna get? If I need exactly 12 do I need to change the gage wire?
Thanks |
03-04-2021, 10:04 PM | #9 |
Post Whore
Re: Hei Distributor
You need to check the voltage at the BAT connection on the HEI as the factory wire from the firewall connector is a resistor wire that will drop the voltage even more before it gets to the HEI.
Check the voltage running. 11.9 volts at the HEI would be a bit low, but should be okay. But the lower voltage in conjunction with another one of the previously mentioned issues could be causing the failures. In addition a failing pickup ring could be causing or contributing to the failures. Your best course of action would be to take your distributor to someone with a distributor machine and who is versed in troubleshooting HEIs. That way you should be able to pinpoint the failure points and not just change parts hoping that you solve the problem. A 14 guage wire will be sufficient for the HEI. You may want to check out why your voltage is low at the bulkhead connector. Is there more than a half a volt difference between the battery voltage and the voltage at the connector. If so you need to trace the voltage back to the ignition switch to find where your voltage is dropping at. Good luck and keep us posted.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 03-04-2021 at 10:11 PM. |
03-05-2021, 11:41 AM | #10 |
Re: Hei Distributor
The 11.9 volt reading im getting is with the key in the on postion not running. If running I should get a higher volt reading through the wire but the control module should adjust the voltage going in correct. So from what im gathering is the 11.9 volt should be fine for the on postion?
03-05-2021, 12:05 PM | #11 |
Post Whore
Re: Hei Distributor
The reason to check the voltage at the HEI terminal with the engine running is when the HEI is providing spark its amp draw is at or near maximum.
If you have a poor connection in the wiring to the HEI the voltage being supplied to the HEI will drop. Since you are looking for the cause of repeated failures you are hoping to discover something that is on the nearly out of specification. So you may find that the 11.9 volts you measured with the engine off may be less with the engine running. I am assuming by control module you mean the voltage regulator in the alternator which only regulates the voltage at the point the alternator sensor wiring is connected to. The sensor wire generally not connected to the ignition wiring directly.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-05-2021, 01:57 PM | #12 |
Re: Hei Distributor
I disagree with the statement that a 14 gauge wire is sufficient. I would run a new 12 gauge wire from the junction block to the distributor. On vehicles that came from the factory with HEI ignition, the wire is 12 gauge.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-05-2021, 02:29 PM | #13 | |
Re: Hei Distributor
i know there are folks that will disagree but it happened like clockwork every time. |
