Old 03-05-2021, 10:28 PM   #1
kennyhammond
2002 z71 15 inch rims???
So thinking of lifting the ole z71 work truck up 6 inch. J want to get the ole school 15 inch rim possibly get 35x12.50 boggers or swampers in a 15x10 rim What is needed to make this work
kennyhammond is offline   Reply With Quote
Old 03-07-2021, 08:22 AM   #2
Re: 2002 z71 15 inch rims???
I tried on my 2002 W/T, but the 15" wheels would not clear the disc brake calipers. Yours would have the bigger calipers, so it would be even more of an issue. I was attempting to use 15x8 ralleys.
Old 03-07-2021, 11:06 AM   #3
kennyhammond
What did you go with. I have 20 factory rims with 33x12.50. Wanting to up it and get more tire. Might drop to a 18inch and 35 or 36 14.50
Old 03-07-2021, 12:04 PM   #4
I had 16" x8" steel wagon wheels. If I could have found 17x8 or 17x9 wagon wheels or steels I probably would have used them.
Old 03-10-2021, 02:53 PM   #5
biketopia
16"s will clear fine, that was what came on them stock.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 03-13-2021, 12:58 PM   #6
kennyhammond
Gotcha. Might just use the 18s with a 13.50 wide tire. Guessing I will need a 4 inch lift to clear 33x14,50. Not really wanting to go 6inch
