![]() Join Date: Aug 2015
Rochester Quadrajet Help
1972 C10, 350/4 bolt
had a new fuel pump and new filter at the carburetor installed original fuel pump would cut out /spring was broken seemed to fix that issue mechanical fuel pump now having another issue, truck starts ok, runs ok most of the time, does try to idle down, it will die if you let it, but after it warms up and you shut it off, you have to push pedal all the way to floor to start , like its flooded used to start up barely spin when warm was checking today and in the picture, the black rubber cap with yellow marks, when i changed it, fuel was coming out, is this normal ? might just go with a new edelbrock 1406 if i need a new carburetor Thanks
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
![]() Join Date: Dec 2009
Re: Rochester Quadrajet Help
Sounds like the float is stuck open.
That is the first thing I would check. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
hi,sounds like it is flooding?did the carb come apart?float set to high,possibly some crap stuck in the needle and seat if you were changing filters?is the filter installed in the correct direction?that isn't the correct carb for a 72 engine,it's a later carb,the 5th digit in the numbers on the drivers side of the carb back by the secondaries will tell you what year engine it was originally on.i always have better luck with the old quadrajets but that one you have should run well too.
I bought a remanufactured Quadrajet from National Carburetors a month ago. It was only $229.95 + 100.00 core charge. Installed it on the motor and after a little "tweaking" was running fine. Carburetor was Rochester 4MV.
I also bought remanufactured quadrajet from Summit racing but it would not run correctly out of the box. It was also around the $350 price range. |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
one thing to check, if you haven't already, to see if you have contaminants in your fuel. Say like crap in your tank.
I only bring this up as this was my problem. After I bought my truck, my brother rebuilt the engine / transmission, including rebuilding the carb. After I went to go get it, it started do so a lot of what you are talking about. He pulled the carb (which is a Rochester Quadrajet like yours) and it was full of sediment. The tank was pulled, cleaned and lined at a radiator shop. Fixed that problem 100%. Oh, the PO put on a 78 QJet Carter. I got a matching number Qjet Rochester off ebay for my 72 Truck and I have sent that off to https://quadrajetpower.com/ to be fully worked on and tweaking it. Though I am not expecting it before the end of April or sometime in May. The guy is crazy backed up ![]()
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 03-07-2021 at 02:26 AM. |
Sorry, the motor is not the same as the truck motor is a 1979 ElCamino motor the carb has never been adjusted, the covers for the air/fuel are still there the fuel filter was changed with the fuel pump ill pull the carb off tomorrow and check for junk or float
![]() Join Date: Aug 2019
You replaced the fuel pump? I have read a lot of threads on here about replacement fuel pumps putting out to much fuel pressure.
hi,no need to be sorry,if the adjustment plugs are there in place,the carb has likely never been apart and the float is probably set correctly but it could also be pretty dirty in there.as Richard said,his tank was full of trash so in order to keep the carb clean,the tank has to be clean.if you don't know what kind of shape your tank is in that might be a place to look.a trick i've used on the road when i had a flooding problem and nothing to work with for tools,go buy a can of fuel system cleaner,dump it in the gas,get the engine running with a moderate RPM and tap with a dead blow or rubber hammer on the front of the carb,right around that big 1 inch nut where the fuel line goes in,sometimes you get lucky and whatever is holding the needle open,will pass through.temporary fix but it would be worth a try to see if you make any progress.good luck.we'll be waiting for an update.Greg
Mr. Cheyenne
My brother and I kicked ourselves in the butt over the fuel tank - we did a lot of things, like replacing the fuel pump, before figuring out it was a nasty tank. The sad part is we had a good sign the tank needed at least checking when we had to replace the sending unit because the float was 1/3 (if not more) rusted away causing the fuel gauge not to work.
Hind sight is sooo 20/20 on my thread from last year. After reading it over again we were also fighting a bad carb I got off eBay - which is one of the main reason when I finally got what I think is is good replacement I sent it off to Quadjet Power. Everything I have read is nothing beats a properly turned Qjet! You very well may be dealing with a Carb that needs to be rebuilt but insuring your tank is in good shape, IMO, is a good thing to check out and to eliminate as an issue.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
Rebuild the carb. Good place for a kit is Quadrajetparts.com. Flooding can be caused by needle valve not seating or well plugs leaking. 1705xxxxx carbs usually don’t have the leaking well plug problem. Quadrajet are super simple and easy to rebuild. Choke/pull down are most fiddle bits. Probably should pull the idle tubes before cleaning. If you careful, you can get out originals and still be able to reuse.
Edit: Just noticed, you have a 1708 carb which is post 1976, so probably the well plugs are not the cause for flooding |
Post Whore
![]() Join Date: Feb 2016
As folks have said your float level is incorrect. One very common cause of that issue is for the float to have sunk.
On a brass float it can get a small hole in it allowing fuel inside. This is easy to determine by shaking the float. You can feel/hear liquid inside. A composite float will absorb fuel overtime and become heavy, and won't float as high as they should causing flooding. You can compare the weight of a new float to yours to confirm it has become fuel soaked. Both versions can have the float level reset to temporarily repair the issue, (and to help troubleshoot the issue) but a new float is recommended.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks for all the Help
might of fixed it, the new filter came with a shorter spring, swapped it with another one from another quadrajet and seems ok now Again appreciate all the help
#13 |
Filter has nothing to do with flooding. If the carb inlet filter has the wrong spring, it could cause the filter to unseat and be ineffective.
#14 |
Took the truck for a spin to the local Menard's, runs good, but still seems like it was flooded on startup, had to push pedal to floor to start
same when i got back home, shut off and wouldnt start till i pushed pedal to floor ill get it pulled sometime this week Thank's
