Electronic Gauge
I am debating using a 1990 suburban gauge in my 1981 c10. Anyone done this swap and anything i need to know before doing it? Like how to wire it in or connectors or anything? doing this with the plan of LS later.
Builds: 1962 C10 Recreating Dad's High School Truck 1981 C10 |
Re: Electronic Gauge
It is actually quite simple to do. You have to move just about every wire in the plug. I used a pick tool. The diagrams are readily available with a simple search on this forum. It is amazing when everything works.
This was the placement for '84 |
If you're needing the pinouts, confirm that your cluster looks the same or has the same part number as the third one in this facebook post. If so, one of these should be accurate for a 1990/91 cluster. If your cluster is different, I would be interested in several photos of it to add to my pinout collection.
https://www.facebook.com/groups/2678...10913745771789
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
