Need opinions on this door latch
The fact that my driver door wouldn't latch reliably was making me crazy, so a while back I bought a new latch and new relay from a vendor who has a good reputation on here. Things are no better, maybe worse. I've tried various adjustment tips I've seen on here, with almost no difference. The only way I can get the door to latch consistently is to adjust it so that the door hangs out about 3/4" from the body when fully latched.
I finally started looking at the latch more closely, and noticed that the 'gear' (or whatever it's called) has quite a bit of play in it. I'm wondering if this play causes the door to latch initially, then back off enough to come unlatched. Here's a video of the new latch and the amount of play: Driver Side New Latch video Here a video of the passenger side with the older/original latch. It has much less play as you can see, and this door latches fine. Passenger Latch video I assume I need to just toss this new latch and try again? Does anyone sell a decent quality latch? (I took a long time to install the latch, then fought with it for nearly a year, so it's way too late to try to return it). Thanks in advance for any advice. Jon |
![]() Join Date: Aug 2019
Re: Need opinions on this door latch
Have you tried to shut the door without the door seal in place? I have read that a lot of door latching problems are caused by the seal. Take the seal off and see if it makes any difference at all.
![]() Join Date: Mar 2015
After watching your video I would diffidently replace the latch.
I just purchased one for Classic Parts. Item 18-531 for $47.95. Sure seems to be better than the one you highlighted in your video. |
![]() Join Date: Jun 2014
There's nothing like NOS OEM parts... Expensive? Yes, I did the aftermarket stuff, it's crap!
RP |
#5 | ||
Jon |
It will be Monday till I can get to it.
But I will check it out for you. While I agree much of the aftermarket stuff is crap as you put it. Much of it is very good and sometimes better than original. An example that comes to mind it the door sills. I have purchased them from GM back when and they didn't last long in our weather. The aftermarket came out with Stainless sills. Look like new for years. The aftermarket is keeping many of the trucks alive and adding to their value. I am the first to advertise bad parts as junk. But I also know that they are not all bad. Rick Last edited by Accelo; 03-13-2021 at 07:48 PM. |
