1972 GMC Power Steering Pump bolt leak
I have a leak from one of the lower pump mounting bolts. There appears to be a white plastic like washer/seal between the hex nut and the pump body. I plan to replace it with a new seal and flat washer to push the seal. Anyone have an idea what material seal I should use? see photo of pump backside. Thanks for any help
Re: 1972 GMC Power Steering Pump bolt leak
The seal (rubber) is between the tank and pump on the inside. Looks like someone is just trying to patch it up.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
OK - I am not sure what seals I need and where they go. Where can I get an exploded view with parts list? thanks for your halp
#4 | |
https://www.oreillyauto.com/shop/b/s...+seal+kit-pump |
There's also the Edelmann 7910. I'm sure any rebuild kit will be fine
72 C10 lwb fleetside -stock 350/350 combo |
I'm think I used thin copper washers to seal those spots years ago
