03-22-2021, 10:35 PM | #1 |
1970 GMC Floor Mounted Gas Pedal replacement
I'm finishing up a sniper EFI conversion with a lokar throttle cable hook up. My pickup is a manual transmission with a original floor mounted gas pedal.
Do I have to replace this with a aftermarket floor mounted pedal or is it easier to install the firewall mounted one? LOKAR has both floor mount as well as firewall. Anyone ever done this? I hope this makes sense. Thanks! Fred
1965 LeMans * 1968 CJ5 1969 Firebird * 1970 GMC Truck 1975 Trans Am * 1952 Pickup 1979 Trans Am * 1982 Trans Am 1976 CJ7 * 2000 Trams Am |
03-23-2021, 12:00 AM | #2 |
Who Changed This?
Re: 1970 GMC Floor Mounted Gas Pedal replacement
If your original pedal isn't all cracked and still pivots on the ball studs, I'd say go ahead and run that.
03-23-2021, 12:28 AM | #3 | |
The top of pedal itself presses against a rod that goes thru the firewall which attached to the original throttle cable. Not sure how I could get the old pedal to push or pull against the new throttle cable. Posted via Mobile Device |
03-23-2021, 02:40 AM | #4 |
If you want to convert to a 71-72 cable style gas pedal, then check this out.
http://67-72chevytrucks.com/vboard/s...hlight=Adapter |
03-23-2021, 09:07 AM | #5 | |
03-23-2021, 11:47 AM | #6 |
Thanks Steve, the original pedal is in great shape. Definitely in the mix if the firewall mount goes south.
03-23-2021, 11:49 AM | #7 |
Very helpful, thanks PJ.
03-23-2021, 11:55 AM | #8 |
I love the idea of pulling a pedal out of something else and making it fit for your install. I installed trans am exhaust tips on the end of my trucks tail pipes. No one knows they match my trans am but me.
If I install the LOKAR pedal attached to the firewall, I will have hole in the caret.. which will get replaced anyways but maybe some nice mats will cover it in the mean time. I also called LOAKR and they did say that the NEW gas pedal will sit closer to the firewall than the original floor mount pedal... I guess I will just have to get used to that.
03-23-2021, 12:06 PM | #9 |
Here are a couple of photos before I start tearing everything apart. Don't judge the mess under the dash...
03-23-2021, 12:26 PM | #10 |
I did this upgrade fairly recently. It took a little while to get used to the firewall mounted pedal instead of floor mounted, but I never looked back. It felt a lot more responsive and tactile. It's worth noting that my linkage was pretty worn out, which is why I did this upgrade. I would totally recommend it. There's a board member who makes the adapter plates and sells them so it just bolts right in. I'd say it took me... 2 hours? Including driving to the parts store. Make sure you get the right throttle cable/bracket/ball stud to mount it all.
1968 GMC C2500 Long Bed Fleetside |
03-23-2021, 12:46 PM | #11 |
Thanks for the feedback on the new pedal position.. sometimes I get tied up on something when it changes... but I'm sure I will love the new responsiveness compared to what was there.
PJ posted the link to the adapter. Hopefully I ordered the right parts as well! Thanks again.
04-03-2021, 10:54 AM | #12 |
Here is an update : I drilled out the two of the three original threaded holes like the loose instructions said too. Also drilled out the hole for the throttle cable just above the pedal location. Bolted everything up and connected the throttle body to the cable and pedal and so far so good. Here are some photos
Thanks for everyone’s input.
1965 LeMans * 1968 CJ5 1969 Firebird * 1970 GMC Truck 1975 Trans Am * 1952 Pickup 1979 Trans Am * 1982 Trans Am 1976 CJ7 * 2000 Trams Am Last edited by 1badtransam; 04-03-2021 at 11:09 AM. |
Tags |
firewall mount, floor mount, gas pedal conversion, lokar |
