Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 4x4
Old 03-23-2021, 03:56 PM   #1
1960chevypanel
4x4 question, do front and rear gear sets interchange?
Does anyone know if you can you swap a gear set from a front end into a rear end? Both are Dana 44.
1960chevypanel is offline   Reply With Quote
Old 03-25-2021, 11:47 AM   #2
bsarts
bsarts's Avatar
Re: 4x4 question, do front and rear gear sets interchange?
Typically, the front end has a slightly lower ratio than the rear so that the front end will pull.
bsarts is offline   Reply With Quote
Old 03-26-2021, 09:42 AM   #3
60-66
60-66's Avatar
Easiest way to figure that out is , remove the axle covers and check the GM Part numbers on the ring and pinion. Should be the same , as the GMC parts book does not specify by 10 or K10 for the gear sets
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
