03-24-2021, 03:40 PM | #1 |
1969 K10 clutch options
Looking for advice on a clutch kit. I currently have a SACHS 12" kit in the truck and the pedal is very heavy ( wife has an issue driving the truck ). Just wondering if anyone had experience with an aftermarket kit that would reduce pedal effort. The truck has a new small block in it with the SM465 trans and doesn't get abused so I am not concerned about maximum holding power.
03-24-2021, 06:12 PM | #2 |
Re: 1969 K10 clutch options
3 finger or diaphragm clutch??. Diaphragm clutches are easier with the same clamping pressure. If she is having problems with the diaphragm, you may have to go hydraulic
03-24-2021, 06:41 PM | #3 |
All about them K’s
I used a LUK 12” kit from Napa in my K20. Couldn’t be happier with it. It’s supposed to be the same as the stock clutch. I’ve got a hydraulic setup in my truck so it’s got a light pedal but I don’t see why it would be heavier than a stock clutch with a mechanical setup.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
