Old 03-24-2021, 10:49 PM   #1
Bobbysgmc
Rearend swap
Have a chance to get a 87 Suburban rear end.Is it feasible to consider swapping it into my 71-C20? Pros and cons.....
Bobbysgmc is offline   Reply With Quote
Old 03-25-2021, 04:50 PM   #2
MDPotter
MDPotter's Avatar
Re: Rearend swap
Anything can be done, but the amount of work depends on what it is. What is in your C-20 now? What is the suburban rear end? What are you gaining?
Whatever it is, you have to consider spring perches/trailing arm mounts, shock mounts, brakes, pinion yoke, gearing, rear end width, etc.
I swapped a 12-bolt from a 73-80 K10 into my C10 and it wasn't too bad but does involve some work.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 03-25-2021, 05:03 PM   #3
gmc684x4
Re: Rearend swap
Is your truck ho52 eaton or dana 60?
Leaf or coil rear suspension?
If leaf springs it will be easy
What is the 87 is it a 14 bolt ?
14 bolts can be made made to work with coils spryng trucks with some work
gmc684x4 is offline   Reply With Quote
