03-27-2021, 03:04 PM | #1 |
Is there anything wrong in this picture?
Please will an experienced eye look at my photos of my accesory drive and see if you spot anything wrong. If a couple of symptoms mainly belt ratio related i think
69 longbed 350 700r4 3.73 POSI cruiser |
03-27-2021, 03:06 PM | #2 |
Re: Is there anything wrong in this picture?
Another
03-27-2021, 03:09 PM | #3 |
Have to post separately for some reason
03-27-2021, 03:38 PM | #4 |
On the wrong pulley
03-27-2021, 03:52 PM | #5 |
Thanks mac!which one is wrong? Is it the water pump pulley?
03-27-2021, 04:35 PM | #6 |
I don't know, but you can remove that spacer for the mechanical fan if you like. There's no need for it with the electric fans
03-27-2021, 04:47 PM | #7 |
The top of your water pump belt is setting above the top of the the pulley, it should be fully inside the pulley, like the power steering belt.
03-27-2021, 05:58 PM | #8 |
Water pump belt is too wide and as stated, does not fully seat into the pully groove. Measure the width and depth of the groove and belt length. Good parts store should be able to hook you up.
03-27-2021, 06:22 PM | #9 |
Power Steering Top Brackets Wrong WATER pump Pulley Crooked Belt Cog To Fat,
Get Rid Of Spacer
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
03-28-2021, 03:01 PM | #10 |
Thanks everybody gives me a few jobs to tidy up! I think I have a problem with slow water flow on idle which is 550rpm. It is not flowing fast enough for my fan switch to knock off. It's a 165-185 fan switch installed in the thermostat neck which is a 160stat. There is a huge temp drop across the rad and when I press gas I feel the heat rush through. I have a 7/78 crank pulley and 6.5 inch water pump pulley. I read approx 130% overdrive ratio was good on the water pump for street and I'm a bit under. Not sure which pulley to change. To add to the confusion my alternator is kicking out 16v and is being driven from the same 7/78 crank pulley and wondered if i was overspeeding it. Thanks for all your help iv confused myself and doing Google searches has just added to the confusion
03-28-2021, 03:08 PM | #11 | ||
"I ain't nobody, dork."
Hard to piece together all the front bracketry to line up. For parts sourcing, that is a later model (1973+ for trucks) SBC setup. The 67-72's all had alternators on the drivers side.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-28-2021, 03:34 PM | #12 | |
03-28-2021, 05:54 PM | #13 | |
Who Changed This?
03-29-2021, 05:18 PM | #14 | |
03-29-2021, 05:23 PM | #15 |
Thanks Gary thats useull info will keep that in mind
03-29-2021, 05:26 PM | #16 |
thanks steeveedee it's internally regulated so I take it I have to buy anew alteenator then. Thanks for the info
03-30-2021, 10:57 AM | #17 |
Ummm, what??
72 C10 lwb fleetside -stock 350/350 combo |
03-30-2021, 10:59 AM | #18 | ||
All the V8 trucks did. Also all the V8 trucks (SBC and BBC) had short water pumps.
Gary
03-30-2021, 11:01 AM | #19 |
Wow, I never noticed Learn something new everyday. For some reason I had it in my head that only a/c trucks have it on the drivers side. So trucks with passenger side alts were using later model bracketry?
03-30-2021, 11:04 AM | #20 |
Alternator on drivers side 67-72 like this . Mine has an aftermarket ac system
03-30-2021, 11:06 AM | #21 |
Or the engine was replaced at some time . My 72 is on the passenger side the engine from what I can decifer came from a 74
03-30-2021, 11:09 AM | #22 | |||
Gary
03-31-2021, 03:01 PM | #23 |
Well the block is an 010 so I thought it could be 69 to early 70s engine. So prob is a 73. Heads are 991 76cc small valve deals. Obviously no engine vin on these's trucks so guess I'll never know
03-31-2021, 03:05 PM | #24 | |||
Also the machined pad in front of the passenger side head will have some alphanumerics as well. They can be decoded to break it down even more. Gary
