Old member
Need idea's on how to mount this gear shifter idea.
I bought these last week at the beach. Need to get some idea's on how to mount it. I got a bolt and ordered a set of couplers to extend it up a little higher in the truck. The threads are 3/8" x24. I need some idea's on how to mount it with out having the nut in it's head. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 2009
Re: Gear shifter....
Slow cure epoxy?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Why dont you want a nut inside the head ? My experience is without a nut and locking nut the shift ball will start to rotate . Guess JBWELD would work but without metal threads it will ware out and strip
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 04-02-2021 at 09:04 AM. |
Fill it full of JB weld. Install a helicoil. JB weld drills and taps. Then it can be screwed down and anchored with a jam nut.
Old member
I don't want anything to be seen on the outside of it. Not worried about inside it. I didn't want to drill the top of it to do a nut are bolt.
JB weld may be a idea. I also may could use plumbers roll also. It can be drilled and tapped also. ![]()
Old member
I temporarily have the skull mounted and wired into the lights. I'm thinking I need to round the wood off and countersink to fit the shifter rod better than the square end.
#7 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Old member
Thanks. It should look good with skully sitting beside it.
