![]() Join Date: Mar 2015
Tilt column shift lever
I have an original tilt column out of a 67-72 truck.
My description may be inaccurate as I am unsure of the actual build date of the column. I have three questions; What years did GM start offer a tilt column in the 67-72 series trucks? I have serious doubts it was available all five years. Is there an easy way to tell what year column I have? I need to purchase a automatic shift lever for it as the original was missing. I want to be sure to get the correct part.(s). Are the non-tilt transmission shift handles the same as the tilt column handles? My best guess by looking at the online catalogs is they interchange. But have little to no faith in the interchanged published by most companies. Rick |
Roadtrip!
![]() Join Date: Feb 2003
Re: Tilt column shift lever
I think the tilt came out in 70. The tilt lever is different than a regular column. The original truck levers are shorter than the later van ones, but will work. Just make sure you order a tilt one.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Jul 2003
The original truck shifter lever is much longer than the van levers.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Roadtrip!
You are correct...
