Old 03-30-2021, 11:09 PM   #1
Peanut74
Wiring in a remote windshield washer
I think I know the answer to my question but wanted to be sure I was right.
I want to wire in a remote windshield washer and tank. What I am thinking is that the yellow wire #963 is the power (+12V) side and the Blue wire #965 is the ground.
To wire in the remote washer I would tap into both wires to power the washer motor. Am I correct or am I missing something?
I've been trying to figure this out for a couple of hours and I am starting to go in circles.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 03-31-2021, 02:29 AM   #2
bassxlr8r
Re: Wiring in a remote windshield washer
That is correct. The motor has the +12v supplied via the fuse box (yellow), and the grounds to activate high/low/washer (lt. blue, black, blue) are supplied through the OEM switch in the diagram. If you're using an aftermarket switch, make sure provisions for the washer are built in as some do not support this function.
bassxlr8r is offline   Reply With Quote
Old 03-31-2021, 07:37 AM   #3
Richard2112
Richard2112's Avatar
I just did this same thing. Mounted my squirter nozzles on my hood though.
Richard2112 is offline   Reply With Quote
Old 03-31-2021, 08:38 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Wiring in a remote windshield washer
Power is straight to pump. The knob in the dash makes ground. Power can come from anywhere. Just ground it back to the dash knob. Read this post and it will show you what you need to do on the 2 page.
http://67-72chevytrucks.com/vboard/s...=706191&page=2
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-31-2021, 10:23 AM   #5
Peanut74
Thanks for the confirmation guys. This a case of me over analyzing things again.
This is a case of a color blind guy trying to wire in an after market harness and trying to match it up with factory colors that are faded. Just not use to having the ground active the circuit rather than the power side.
Old 03-31-2021, 07:51 PM   #6
Andy4639
Old member
Andy4639's Avatar
It got me to the first time!
Old 04-02-2021, 08:55 AM   #7
Peanut74
Well I got it all wired up yesterday. Today I want to test the functional circuit and make sure it works. I'm planning on running power to the wiper motor tab in fuse box. I'll run the ground from the battery to the wiper switch. Wish me luck!!
