Old 03-31-2021, 06:51 PM   #1
72-CH
72-CH's Avatar
Headlight relay
Does anyone know where I can find the original style headlight relay or know the AC Delco/ Delco Remy part number? It's on a 72.
Thanks,
72-CH is offline   Reply With Quote
Old 03-31-2021, 07:45 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Headlight relay
Do you mean the high/low beam foot switch?
There is no headlight relay from the factory.
PS Welcome aboard!
RIP Bob Parks.
Old 03-31-2021, 08:35 PM   #3
72-CH
72-CH's Avatar
Re: Headlight relay
This is the part I was referring to.
Old 03-31-2021, 08:53 PM   #4
dmjlambert
dmjlambert's Avatar
Re: Headlight relay
That is the voltage regulator for the charging system. There is some recent discussion including adjustment and quality of replacements here http://67-72chevytrucks.com/vboard/s...d.php?t=820074. It's possible to clean it up and paint it and restore the interior by burnishing the contacts and adjusting.
dmjlambert is offline   Reply With Quote
Old 03-31-2021, 09:02 PM   #5
firedemon
Re: Headlight relay
thats definitely the voltage regulator what problem are you having that you thought you need to change a headlight relay
firedemon is offline   Reply With Quote
Old 03-31-2021, 11:19 PM   #6
72-CH
72-CH's Avatar
Re: Headlight relay
Thanks for all the replies, not having a problem with lights, just doing some clean up under the hood.
Old 04-01-2021, 06:22 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Headlight relay
Use a wirebrush on the outside and spraypaint your Voltage Regulator in satin black. If it works well -- charges battery and limits alternator overrun -- then don't mess with the internals. They were built to be adjustable, but without the proper set up and knowledge, it's too easy to mess it up. New replacement VRs are junk. Keep the old one if it works.
'68OrangeSunshine is online now   Reply With Quote
Old 04-01-2021, 09:10 PM   #8
firedemon
Re: Headlight relay
glad everything is working but you can get rid of the regulator by going with a more modern alternator if you really wanted it clean
Old 04-02-2021, 02:32 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Headlight relay
I bought a new voltage regulator, from Napa, and and swapped the cases and reinstall on truck. Just trying to keep the truck looking natural.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
