The Living Nightmare of Speedo Gears
Last year my hands were tied between a new baby and moving out of town and I ended up buying a TH350 from Summit. I made the mistake of going to a friend's shop to put it in (instead of doing it myself) and I got it back, installed with no speedo reading. I mentioned this to him and he automatically assumed something unrelated and had already left for the day by the time I got down the street. Long story short I discovered the absence of the driven and drive gears inside the transmission. Conveniently, my old transmission was already gone (in spite of the fact I wanted it back) which had the accurate gears installed.
So I took the suggestion of some of you on the forum to buy the master kit on eBay. http://vi.raptor.ebaydesc.com/ws/eBa...27672000&ver=0 According to the seller, "For the drive gears: red 7, orange 8, green 9, and blue 10. For the driven gears: brown 18, white 19, blue 20, red 21, and grey 22." Since it's like throwing darts I installed the red set. At 60 MPH I'm reading 41 on the speedo. Before I go through the headache of dropping my yoke and tail shaft again, does anyone know the combination I should be using? I've tried using the various calc tools online but they really aren't telling me anything. I've got the standard 3.07 / 3.08 rear, sitting on 235/75R15s. Last edited by StoningtonQB; 04-01-2021 at 01:31 PM. |
![]() Join Date: Feb 2000
Re: The Living Nightmare of Speedo Gears
I know, another calculator but this one may help or a quick call to these guys. They helped me a ton with correcting my speedometer.
https://transmissioncenter.net/shop/...ar-calculator/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
![]() Join Date: Jan 2021
Google speed gear chart, I know TCI has a step through chart. Thanks Chuck
Posted via Mobile Device |
What I don't know with these calculators is what to enter for my axle ratio. They want a number from 2 to 10.
Is there a rule of thumb where if you use less teeth it spins faster (MPH increase per tooth)? Assuming I want the least amount of teeth if my speedo is that slow, correct? |
Not sure why you can't manually enter 3.07 or 3.08 if that is your gear ratio
Maybe I'm off base here but is the driven gear the one that goes on the torpedo that cable connect to?
if so I just pulled that piece out without removing the yoke and swapped the gear. took less than 2 minutes. Again... one thing Ive not dug into is transmissions but just a thought. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
I enabled scripts and it let me enter my ratio. But I'm still not understanding this... it says with 7 teeth and my ratio / tire size I need 28.87 teeth. There isn't a driven gear that has that many.
Then try the 8,9 or 10 tooth in your equation till your get the right combination for the gears that you have.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
![]() Join Date: Oct 2005
There are 2 different types of gears on these trans. The older ones had a bullet shaped holder with the driven gear smaller then the holder. It used about 16 to 23 tooth gears. The Latter models used a large aluminum holder with a gear of about 28-42 teeth.
That is probably what that listing is refering to. You evidently have the small one. George |
![]() ![]() Join Date: Jan 2005
I used this calculator:
https://www.tciauto.com/speedometer-gear-calculator If I plug in your tire specs, it says your tire diameter is 28.88". If I enter that into the calculator, along with a 3.07 ratio and your red 7t drive gear, it says you need a 15t driven gear, which you don't have. If I bump the drive gear up to the 9t, then it says you need a 19t driven gear, and you have both of those sizes. |
Here's another way to look at it. Your speedometer says 41 when you are going 60 (according to GPS I presume) with both red gears.
You need to increase the gear ratio by 60/41 or 1.463 Your current ratio is 7t/21t or .333 If you increase your .333 ratio by 1.463, then you get .333 x 1.463 = .488 The gears I mentioned above will give you pretty close to that. 9t/19t = .473 It will be off by about 3%, which is good enough in my opinion. |
I too had the same issue, tried the calculators, but did not feel confident in the data. So i downloaded an app called Speed Box, then swapped out the speedo cable gear until i got close enough. 2 weeks later something sprung and no more speedo. Now its about the tack or depending on where i am its about keeping up with traffic, or a bit lower. If i am really concerned, i just fire up the app.
#13 | |
