Old 04-02-2021, 10:02 PM   #1
PaddyR
Vintage Air evaporator lines
I’m installing a Vintage Air Sure Fit kit in a 1970 non air. I’ve got the evaporator on the bench installing the mounting brackets and the four lines. How do I position and tighten the lines to make sure the location and spacing is correct to fit thru the firewall grommets? Appreciate the help
PaddyR is offline   Reply With Quote
Old 04-02-2021, 11:55 PM   #2
lux
Re: Vintage Air evaporator lines
I've installed 2 of them so far and I don't remember it being a big problem. I used a tape measurer to get it as close as I could on the work bench. Then when you install it those lines actually have a lot of flex. I some how got it right on the first try both times,, So I think you'll do just fine.
lux is offline   Reply With Quote
Old 04-03-2021, 01:20 AM   #3
Accelo
Accelo's Avatar
I just mounted the adapter plate that covers the stock holes and then mounted the evaporator on the inside. Honestly it fit better than I had hoped. The lines are aluminum and a slight tweak is easy enough to do.
Included is a picture of the vintage Air Condenser that may help if you haven't finished that part. I just completed this the day before yesterday. I can't believe how nice their evaporator fit. Didn't have to tweak a thing. Used all factory holes. Flat amazing. Ive gotten used to the China reproduction stuff and to have it fit like it does just blows me away. Great Job Vintage Air.
Accelo is offline   Reply With Quote
Old 04-03-2021, 08:48 AM   #4
PaddyR
Thanks Lux, so the #10 suction line rests on top of the evaporator and you measured down from there?
Old 04-03-2021, 08:57 AM   #5
PaddyR
Thanks Accelo, I have to agree the condenser brackets and lines fit perfectly from Vintage. Their customer service is excellent, Marx Henry looked after a couple shipment issues and prepaid the items to my door in Canada.
Old 04-03-2021, 09:11 AM   #6
MrBlue
MrBlue's Avatar
I’m just finishing my install of a Vintage Air unit. I used the firewall plate as a template to make a thin plywood board with the same holes. Then put this over the 4 lines before tightening them. Worked like a dream!
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 04-03-2021, 09:18 AM   #7
PaddyR
Perfect, was thinking of making one out of cardboard. As I asked Lux did you let the #10 suction line rest on top of the evaporator as your starting point?
