04-11-2021, 06:30 PM | #1 |
60-62 4 speed steering column
Got a 4 speed steering column. It probably needs bearings, but looks like it has the wiring for the turn signal switch in tact. Currently not able to ship because I don't have my steering wheel puller here in Milledgeville.
The steering wheel has cracks, but it is the bigger wheel. $130 for column with the steering wheel. $100 for just column $50 for steering wheel if you want me to pull it off the column. - $old I don't have the time to get quotes to ship stuff right now, so local pickup on these. Also have a set of hood hinges with springs. Will update with price after I check how much play is in the rivets
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 06-19-2021 at 04:13 PM. |
05-11-2021, 09:44 PM | #2 |
Re: 60-62 4 speed steering column
Ttt
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-19-2021, 04:13 PM | #3 |
Steering wheel sold for $40 locally.
Will sell column for $80. Now that the wheel is gone, I could probably ship the column since it's a lot smaller now
07-15-2021, 11:21 PM | #4 |
Open to offers on the column. If you need it, lets make a deal!
