Overheating -
Just got back from my first race trip, this one in Atlanta.
I drove through the night Thursday night, hitting the city around 8 or 9 am. My truck was running hot, like 250 deg, pulling the grades into and out of Atlanta. We limped it to the track, in Commerce, about 10 am. Ambient temp was about 77 deg, so not terribly hot. I'm looking for suggestions on a potential root cause and solutions. We were able to make it home by turning off the AC and turning on the heat full blast. Actually - we could pretty much control the engine temp by playing with the heater, and kept it solidly at about 210 deg once we made that discovery. As Sunday evening wore on the ambient temps dropped and the ground leveled out so by the time we hit Cincinatah it was about 52 deg and we were home free. By way of reminder, it's an '04 2500HD with the 6.6 Duramax (LB7) and 3.73 gears. Trailer weighs about 7500 lbs with the car in it. Thanks, K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Moderator
![]() Join Date: Oct 2008
Re: Overheating -
Maybe you've seen this. Apparently the cooling fan can push an abnormal amount of hot air into the air filter intake area.
http://www.maxxtorque.com/2008/07/du...ution-and.html This is the service bulletin 06-06-04-036D he references with the GM factory cold air intake arrangement. http://ww2.justanswer.com/uploads/je...verheating.pdf
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-13-2021 at 08:30 PM. |
Re: Overheating -
Thank you; I'm going to make sure that the radiator fins are clean and not damaged, and then fabricate a cold air intake duct.
K
laying low
![]() Join Date: Mar 2001
Re: Overheating -
How long have you owned and towed with that truck? If you've had it for some years and overheating is just now happening I don't believe it's a cold air intake issue. Fan clutch, thermostat and plugged radiator top the list of possible culprits.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: Overheating -
Good point. I've had it since Nov of 2015.
K
Moderator
Re: Overheating -
I read that it was your first trip with it and assumed it was a new acquisition.
Forgot my first rule. Never assume ![]() No problem til you started towing? Do you have any extra gauges like EGT for instance?
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-15-2021 at 05:09 PM. |
Re: Overheating -
Truck update - the whole front of the radiator is covered with oily fuzz, like from a cottonwood tree.
????? Not sure why it would be on the radiator rather than the forwardmost heat exchanger (AC, or charge air cooler). Now I gotta figure out how to get it off there without damaging the fins. K
#8 | |
Re: Overheating -
No extra guages, just factory.
Re: Overheating -
feel the radiator top and bottom with it warm, if the rad is starting to plug up, it will be hot on the top and colder on the bottom.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#10 | |
Moderator
Re: Overheating -
![]() I'd get worried when the water coming in the top is the same temp as or within a handful of degrees of the water going back into the engine. The fluffy oily crud in the fins would reduce the coolilng efficiency of the radiator a whole bunch. Keith, Do you have a tiny leak in an engine-oil/transmission cooler or cooler hose or the AC condenser that's misting a tiny amount of oil into the cooling stack so the radiator is collecting that fluffy crud? I assume the charge air cooler is the leading edge of the cooling stack, then the oil coolers, AC condenser, and finally the radiator. I've had a charge air hose leak blow oil mist into the engine compartment on my 05 Jetta TDI.
And please let us know if and how your repairs were successful. |
#11 | ||
Re: Overheating -
One other point: this issue may have been brewing for a couple years. I was remembering that I would lose AC cooling while stopped for red lights and such, and then it occurred to me that I didn't do any trailering last year due to the pandemic. I was able to clean all the fuzz off the face of the radiator by laying it back (without completely removing it) and spraying the leading side with brake clean and the garden hose. I'm optimistic that this is going to take care of both my problems (although....it's 32 degrees out there right now). K
#12 | |
Re: Overheating -
trust me this works. been using this trick for 30 years to identify plugged radiators.
#13 |
Moderator
Re: Overheating -
If a large section is completely or mostly plugged up it'll be stone cold or very close to that over the affected area. I would guess you could pick that out with a FLIR camera fairly easily. One of the nice things about that kind of tech getting to be more accessible in price.
Mildly restricted flow is a bit more difficult. Experience would make you better able to judge but most of us don't see that kind of problem because we use distilled water rather than tap water so we don't get the calcium deposits and heavy internal corrosion in modern vehicles that we used to see in the '70s & '80s.
#14 |
Re: Overheating -
Just checking back in to say that the fuzz removal process fixed it.
Towed to St Louis and back with no issues. Oh - and:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-19-2021 at 12:46 PM. |
#15 |
![]() ![]() Join Date: Jul 2002
Re: Overheating -
Good to hear it Keith
