05-01-2021, 01:52 PM | #1 |
Amp location
Anybody mount an amp in the center console, would it have enough circulation. I have a sub amp located under the passenger seat and looking for a location for a four channel amp for the front and rear speakers. Did a mock up under the drivers seat and it was a no go. I'm 6'3 so raising the drivers seat is not an option. 4 Channel to passenger and relocate sub amp? Sub is behind rear seat in a custom box. Any Ideas?
05-01-2021, 02:59 PM | #2 |
Re: Amp location
My amp and SUB are in here !
If you're using a Softopper or no top, dont even waste your time putting in a stereo unless you want to listen to tunes while parked. Too noisy when driving. |
05-02-2021, 12:27 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Amp location
Now that's cool
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
05-04-2021, 05:48 PM | #4 |
Re: Amp location
I have 2 amps under rear seat, but they're small-ish in size, one for the speakers and one for the subs. FWIW, I can hear mine great going down the road with no top.
05-05-2021, 01:13 PM | #5 |
Re: Amp location
Ended up with 4 channel under the passenger seat and sub amp under the rear seat
05-05-2021, 01:32 PM | #6 |
Re: Amp location
My amp is under the driver seat...but I had to modify the slider brackets so it would fit
Didn't want it under the passenger seat..exposed every time the seat was tilted forward. I also made some shims from black plastic to raise the rear seat enough to put the sub under it.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
05-05-2021, 07:02 PM | #7 |
Re: Amp location
05-09-2021, 07:43 PM | #8 |
Re: Amp location
I have a 5 channel amp under the rear seat. It drives a single 12" in a box behind the back seat, a pair of 6 1/2" speakers in the side panels right behind the front seats and a pair of 4"s in the door panels. 50x4 and 150x1 if I remember correctly.
I have NO problems hearing my tunes with the windows zipped out of my SpecialtyTopCo soft top.
05-09-2021, 10:18 PM | #9 |
Re: Amp location
Boom.
