05-25-2021, 04:21 PM | #1 |
67-72 rear leaf springs vs 73-87
I have a pair of 52" leaf springs out of my 1978 K10 sitting around. They are 4 inch lift springs from Rough Country and are basically new. I have a 1969 K10 that I am thinking about lifting 4 inches to put 33's on it and I am wondering if these will bolt in. If the measurement from the center of the front eye bolt to the center pin is the same they should fit right? I have the 69 K10 in storage so getting to it to measure the springs is a problem at the moment.
05-25-2021, 09:24 PM | #2 |
All about them K’s
Re: 67-72 rear leaf springs vs 73-87
Are you taking fronts or rears? The 69-72’s use 52” long x about 2.5” wide rear springs if I remember correctly so if the widths are the same it should work. I haven’t messed with a K 73-87 in a little bit so I don’t remember the lengths and widths. I know the front springs are Definitely longer on the 73-87 vs. the 67-72’s.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
