06-04-2021, 07:28 PM | #1 |
Bed/body alignment issues
I am fixing a few things on my Jimmy and found that the right hand side bed rail isn't square at the door. Measuring between the bed rails it is 1/4" wider at the front than the back, and the passenger door sticks out at the bottom, indicating this is the problem area.
I double checked by measuring crosswise between the opposite side and the measurements are 3/8" to 1/2" different. Has anyone had to correct this on their blazer or jimmy? I am considering using the door striker bolts on the driver and passenger doors and building a tube frame to pull and brace against. Would this be strong enough or will I need to add some additional bracing to the uprights?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
06-05-2021, 09:41 AM | #2 |
Re: Bed/body alignment issues
You first need to find out if these measurements were out of spec right from the factory, or if you have rust issues causing these. Obviously if it's rust, no aligning in the worls will fix it until the cause of the problem is repaired. These old trucks had huge tolerances, so being out 1/4" isn't that uncommon.
As far as pulling the panels back in alignment, a hydraulic ram (push and pull) will be your best friend. Unfortunately to move something 1/4", you will need to pull it 1" and this may cause paint cracking. I had to do this to my truck also, but I did it before paint. My windshield header was too far rearwards and I was able to push it back into place, but it took a huge amount of force. Your striker area should be strong enough to pull on, but just make sure you use a plate that uses all the bolt holes, dont pull on just one bolt. |
06-07-2021, 05:17 PM | #3 | |
I did some inspection and rust is not the cause of the misalignment. There is some rust in the front seat area near the rocker panels, but everything that supports the front corners of the bed is in good shape. I might have an easier time bringing mine into alignment because the rocker boxes have been cut out. I hadn't considered possible paint cracking issues. Where might cracks show up? If they do show up it will kind of suck, but it was last painted in 1988 and I have several common spots around the Jimmy to fix (door sills, rocker panels, front corners of bed...) that will require removing the paint anyway. I'm planning on making a plate out of 1/4" steel or some thick steel box to pickup on all the bolts.
