06-20-2021, 12:59 PM | #1 |
WTB: '95 HVAC Control Panel
I'm looking
08-17-2021, 05:40 PM | #2 |
Re: WTB: '95 HVAC Control Panel
Still looking. Haven't found any replacement parts available
08-23-2021, 12:36 PM | #3 |
Carpe manana
Does this style differ from that in a 99?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-25-2021, 05:41 AM | #4 |
I'm not sure. I should look it up again. I was going to start a thread asking that question. I understand there are things about the '95s that are one year only under the dash. I need to be sure if I'm buying one used. I see them on Ebay listed as 96-00 (fits 95). If that's true why aren't they listed as 95-00? Maybe it takes a plug adapter, or fits 96-00 (can be made to work for 95)
08-25-2021, 08:52 PM | #5 |
Carpe manana
I’ve got a spare correct for 99 but unsure if it’s compatible or correct for 95
08-26-2021, 08:50 PM | #6 |
Would think that any would work from the GMT400 based Suburbans/Tahoes or C2500 WT. What are they used?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-02-2021, 06:47 PM | #7 |
They are running close to $100 on Ebay. The problem with mine was brittle plastic. The fan switch stopped working and when I replaced it everything I touched broke. I was going to JB Weld the switch to the panel but it went bad in two weeks, before I put the dash back together. So I figure get the whole deal. I started a thread on the message board to see what I can find out
09-03-2021, 07:42 AM | #8 |
Carpe manana
The plastic is really brittle on the OE pieces. I accidentally broke parts from my 99 Suburban when upgrading the stereo and had no luck with a JB Weld repair. I bought a GM replacement but suspect it's no better and probably the same as aftermarket replacements, which are cheaper.
09-04-2021, 07:37 AM | #9 |
Yeah, a vicious cycle. buy a good original used part and it's brittle or buy new replacement with fresh new plastic but inferior quality. I guess I'll try another fan switch until I can find a rare '95-only HVAC control panel with good clips w/o rear window defogger. Shew! That almost took a whole line to type. Won't be easy. I should have added "from a parked in climate controlled garage low mileage CK from a cooler climate"
I went to Chevys, largely, because of parts simplicity and availability. Things have changed along the way.
09-08-2021, 06:54 AM | #10 |
Would any of these work? https://www.amazon.com/Dorman-599-00...NsaWNrPXRydWU=
1997 GMC Sierra Ext 1965 Mustang |
09-08-2021, 08:12 PM | #11 |
I didn't see where they gave what year those are for. I looked that number up and got 96-00 results. Dang! I need to spend $200 on a simple harness adaptor. Twice as much as the cost of the control panel.
