Old 06-25-2021, 03:03 PM   #1
crazy longhorn
Fabricate till you "puke"
20 to 10 series top arms?
Its been a while, but the old crazy man is playing with the longhorn again! The camber will not come on right, due to the 3/4 ton top arms....am looking @ Ride tech top arms (1/2 ton). I understand, that the 10-30 series cross members are pretty much the same, but have to ask about the studs, that mount the top cross shaft for the A-arm? To give a little info, she has 71 lower arms, 75 spindles/ball joints /69/3/4 ton top arms & shafts. My big ?, is will the top studs accept the 1/2 ton cross shaft, or do I need to replace the top studs or mounts? Need help......Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-26-2021, 05:43 PM   #2
crazy longhorn
Re: 20 to 10 series top arms?
Never mind guys.....I have it figured the 3/4 ton takes a 9/16 stud, versus the 7/16 1/2 ton stud. The 1/2 ton arms will not fit.....time to talk with my machinist! crazyL
Old 06-26-2021, 05:45 PM   #3
SCOTI
SCOTI's Avatar
Upper a-arms are the same length between C20 & C10. No camber gain to be had just going to the C10 part. RideTechs stuff is adjustable for offset (Camber) & uses different 'slugs' for Caster.
Moog makes/made an offset upper shaft (k6184) for the stock 73-87 year arms.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-26-2021, 06:19 PM   #4
crazy longhorn
Thanks for the reply Scoti....I had hoped that you & Capt fab would ,chime in The old truck is running one ring off a stock coil, with the 1st inch heated/flattend, to mimic the stock coil, My guess is about a 2 1/2 drop. She has 1 1/2 inch body drop(us old guys call it channeled). With the drop, the old truck does not have many shims to remove, & is about 2 degrees positive on the camber. I am not looking at more drop......love the stance, just want to make the alingment come on Thanks again............longhorn
Old 06-26-2021, 08:09 PM   #5
SCOTI
SCOTI's Avatar
The RTech upper arms utilize the same approach for the increased camber (the shaft is machined more on one side vs. the other) to get an agressive Camber spec. The offset Moog arm does basically the same thing but they're only made for the later bushing style a-arm.
Target a minimum of NEG .5 Camber. There won't be any difference in tire wear @ that setting but corner grip will be better.
Do the Caster mod w/the lower arms as well. it's easy to get 5-6° POS Caster.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-26-2021, 11:17 PM   #6
72MARIO
72MARIO's Avatar
The upper a arms are the same but in my experience the 3/4 ton upper shaft is thicker pushing the top of the wheel out giving you the positive camber.
You could.possibly machine the upper control arm shaft thinner at the mounting points.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-27-2021, 01:24 PM   #7
crazy longhorn
Thanks again to all .....I had thought about moving the lower arm forward. I have a drill press, & can do that mod On the top shaft,do you guys have any thoughts on how much material needs to be shaved ,to give 2/3 degrees ,to get me to that .5 negative on the Camber? Thanks again to all you good guys Longhorn
Old 06-27-2021, 09:51 PM   #8
SCOTI
SCOTI's Avatar
Hhmm..... Guess I would measure the difference between a 3/4 shaft & compare it to a 1/2 (and possibly RideTechs). If they're smaller OD, cut to that dimension.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-28-2021, 01:29 PM   #9
Ben IV
Just installed these with my 70 cross member. Problem is earlier trucks used a round concave washer behind the control arm shaft that matches the convex area around the studs for caster adjustment. 73 and up use a washer that is flat on the back side and curved on the control arm side to match the control arm. If you install both washers you have too much positive camber without any shims.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 06-28-2021, 02:24 PM   #10
SCOTI
SCOTI's Avatar
I recall grinding the convex/concave area until it was flat on one side of some shafts. I don't recall the parts combo used but remember doing it on the table/bench grinder @ work.
I'll look @ my stuff & see if I can jog the memory (I think it was on my dually).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-28-2021, 03:28 PM   #11
crazy longhorn
That is where I am But all of my parts came from a 69-71 truck. My spacers, came from those yrs, & the shims go into the back side of the spacer. I do understand that machining the cross shaft may be the best deal......might have to burn a number, & think about it Many thanks for your thoughts...CL
Old 06-28-2021, 08:50 PM   #12
Ben IV
I may try that or just put the original shafts in. The 73+ shafts have one flat side that could be turned in to just use the earlier washers.
How low are you going? I haven't run into that issue. Only bought these "camber correction" shafts because I got them cheap on marketplace. Just created more work for myself.
69 GMC panel truck
Old 06-29-2021, 01:16 PM   #13
crazy longhorn
I like the drop/stance....2 1/2 on the spring, + 1 1/2 on the body drop.The way the old truck is set up, nothing drags the pavement!. The rear is a flip/relocate brackets, for about a 5 inch drop. With the 4 inch chop top, the top it is about shoulder height on this 5ft 9 old man @ the top.....I do not want lower, just want to bring it (square) with what I have. Longhorn
Old 08-05-2021, 07:24 PM   #14
crazy longhorn
I purchased a caster camber guage, & was able to pull the camber in to 1 degree positive, & the caster to 2 1/2 degrees positive.....should be within factory spec? It will take machine work to get to the custom/performance specs, but that will be over the winter. Thanks to all for replies, Longhorn
Old 08-05-2021, 08:06 PM   #15
SCOTI
SCOTI's Avatar
You want NEG camber not POS for better 'driving'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-06-2021, 03:36 PM   #16
crazy longhorn
I do understand that Scotty....it should be about 1/2 degree negative , on the camber.....but will take machine work on the top shafts to get there. In my understanding, I am within factory specs? Let it run for the season....take it down over the winter & then play with caster/camber My understanding, is that 1/2 neg, to 1 1/2 degree pos is factory spec.....not perfomance spec, but will not kill the tires. Bring it back bud, I have much to learn about thislonghorn
Old 08-06-2021, 05:36 PM   #17
SCOTI
SCOTI's Avatar
Gotcha. Yes, the + camber number you listed would be considered 'in spec'.
I recall the OE target was +0 to +1 camber. This is why I target the .5 NEG as my minimum. Given your limitation, it makes sense to align as best you can w/what you have.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 05:50 PM   #18
crazy longhorn
Thanks again.....with a little help from a good bunch of brother truckers, she will rock Longhorn
Old 08-10-2021, 07:24 PM   #19
SCOTI
SCOTI's Avatar
What series suspension are you running (10 or 20)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-12-2021, 03:03 PM   #20
crazy longhorn
I am running 10 series suspension.....she does have the 20 series top arms/shafts, & a pair of 71 (10 series) lower arms. The rest is 75 10 series, on the spindles, ball joints & outer tie rod ends. The springs are 10 series, with 1 ring off the bottom. I also fabbed shock relocators, trimmed the bump stops & left the steer stop on the lower arms. She also has a 30 series sway bar, with fabbed brackets to fit .IIRC , the bar was flipped upside down to fit. Thanks again.....longhorn
Old 08-12-2021, 03:40 PM   #21
SCOTI
SCOTI's Avatar
I would try drilling out some early C10 upper shafts for the mounting studs to pass through. Wouldn't take much & you get the smaller diameter (thinner) shaft to help your targets.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-13-2021, 02:14 PM   #22
crazy longhorn
Good idea Scoti......I will check that route out. I guess it is a matter of , the cost of parts vs the machine work? All the parts on my truck are fresh(within 6000 miles). Let us go a number& kick back longhorn
Old 08-13-2021, 04:54 PM   #23
SCOTI
SCOTI's Avatar
I don't recall the upsizing of the mounting hardware to be significant if @ all.
Having limited access to early C20's/30's (pre-73), I have been told they utilized 9/16" upper mounting studs but never had one to validate the info personally.
Most later disc brake 1/2 tons utilize 1/2" upper studs. HD trucks were 9/16".
Early pre-disc brake lower control arm U-bolts were 1/2". Post-72 disc brake are 9/16".
I just put calipers on the old/original upper shafts from my 64 as well as a pair of uppers I got from one of N2billets 67-70 builds. These are original shafts & they allow a 9/16" bolt to pass through. The old/original x-member from my 64 has 1/2" upper mounting studs. The post-72 pancaked x-member I have has 1/2" upper mounting studs.
The early shaft diameters are 15/16" & flat where the bolts pass through (no Concave shape). The later shaft I have is 7/8" @ the shaft & ~1" where the stud passes through (w/the Concave notch).
Point of all this is it's quite probable the C10 shafts fit what you have w/o drilling anything. I would check the dimensions for what you have & compare. There might be no gain or @ the minimum a possible 1/8" gain if one side is flat.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
