Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-28-2021, 09:45 AM   #1
Ken1972
Junior Member
Freshly Rebuilt 700R4 Transmission
I have a rebuilt 700R4 transmission for sale, Less than 250 miles since rebuilt and installed, Transmission was Re-built by J&W transmissions, Rockledge, Florida. J&W used all top quality parts but was built for stock feel shifting (firm, not hard). Comes with custom built lock-up torque converter, also by J&W, 1900-2300 stall. This sale also includes:
Painless lockup kit # 60109, Locking stock type dipstick & tube (Black), Modified OEM Pan with drain plug, Stainless Steel cooler lines, bellhousing cover, (2) OEM TV Cables, Overdrive gear selection lens for steering column, extra pan gasket, extra TV Cable seals, extra speedo drive unit, and extra seals.
Also included: one piece drive shaft, Custom built and balanced by Advance driveline in Orlando, Florida. comes with transmission yoke and all new u-joints for 67-72 short bed truck.
This set up is currently installed in my 72 C10 short bed with small block V8 and can be seen and demonstrated as working perfectly before the sale. I would then remove it for you to pick up (I'm located in Central Florida, Brevard County)
I paid over $3500.00 for all the above items, but will take $1,800 OBO for everything listed above.
If you don't need or want the drive shaft, Price is $1,500 OBO
Nothing wrong with anything, Transmission works perfectly, just as it came from GM, just trying to get my truck back to completely stock. Putting the original TH350 back in.
I can show receipts for what I paid thru a PDF on private message.
Ken1972 is offline   Reply With Quote
