Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > 99+ Chevy and GMC Parts Board
Old 06-30-2021, 09:01 PM   #1
Ironhorse
Ironhorse's Avatar
Wanted-2005 Tahoe Key Fob(s)
Well seems my original GM key fob took a dump, will not work longer than a couple weeks with new battery changes. Was told most likely a weak circuit in the fob draining the battery. Not sure I want to try aftermarket fobs so.....
Any one parting a 2005 Tahoe, Suburban, maybe even a Silverado I would guess? Will buy one or a pair. Needs to have the following codes:
GM 15132197
CANADA 109G 12021
MODEL/FCCID LHJ011
"Thinking" fobs from 2003-2006 will work but needs to have that code. Start looking guys thru your parts vehicles,
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 06-05-2022, 03:25 PM   #2
truckdude239
truckdude239's Avatar
Re: Wanted-2005 Tahoe Key Fob(s)
https://www.keylessentryremotefob.co...w-remote-case/ has used oem boards in new shelled
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-05-2022, 08:44 PM   #3
Ironhorse
Ironhorse's Avatar
Thanks for the link but don't need just the outer case, my inner circuit board is shot. Will not hold a battery charge longer than couple weeks at most.
Wellington, Ks
Old 07-02-2022, 02:47 PM   #4
truckdude239
iron those have the circuit boards inside them they use used oem chevy circuit boards inside aftermarket cases
David fuller
2000 Tahoe 5.3l 378
Old 07-03-2022, 01:06 PM   #5
Ironhorse
Ironhorse's Avatar
Thanks for the info and the link, will do some looking into on that.
Wellington, Ks
Old 07-11-2022, 09:41 PM   #6
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
https://boostautoparts.com/collectio...rofit-key-fobs
I put the 2015 style in my 03 2500hd. They are pretty easy to setup.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
