07-17-2021, 04:43 AM | #1 |
Tie rod end help
Hey Guys,
I've got a 69 C10, still got factory 69 Crossmember, have 73-87 upper and lower control arms. I assume the spindles are 73-87 too. Just wondering what tie rod ends I need to get or if there is a way to figure out what's currently being used? Any help much appreciated Cheers |
07-18-2021, 01:28 AM | #2 |
At the body shop.
Re: Tie rod end help
The big end of the taper on my 73 .750 or 3/4"
" That didnt make it any newer " " Dont antique the equipment " |
07-19-2021, 11:05 AM | #3 |
Researching & determining the tie-rod tapers for comparison might help ID what the parts combo is. Most likely it has 71-87 outers if it has disc brakes.
08-05-2021, 07:11 PM | #4 |
Fabricate till you "puke"
It is my understanding, that the 71-72 c-10s have the same lower ball joint, as 73-87. They do however have a different taper on the upper ball joint, & outer tie rod end.....if using 73-87 spindles. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
