Old 08-16-2021, 05:45 AM   #1
Captain X
Captain X's Avatar
Where can i find rims like this? (for 67 3/4 ton)
I have a 1967 Chevy 3/4 ton, and it has the old split rims on it. The thing is, I like the original style of the hubcaps, which use clips rather than the nubs used on later steel rims. I was wondering if there was a such a thing as steel rims which were not split but would take the old style of hubcaps, but I recently had that question answered thanks to this auction sale: https://dakotaauctioneers.nextlot.co.../lots/19576134
Yeah, they call it a 1969, but it was definitely a '67, and the body was in much better shape than the one I am apparently still going to restore, and had a nicer trim level, too, along with these nice rims that were exactly what I was looking for. Unfortunately, someone had a lot more money they could bid with than I did. I'll probably be salty about that for a while, but in the meantime finding rims like this would help a little bit, at least. Anyone know where I might find some?
Captain X is offline   Reply With Quote
Old 08-16-2021, 08:27 AM   #2
geezer#99
geezer#99's Avatar
Re: Where can i find rims like this? (for 67 3/4 ton)
Look around on here.
https://www.akhwheels.com/
geezer#99 is online now   Reply With Quote
Old 08-16-2021, 12:11 PM   #3
weim55
captain X, Did you get a size on the wheels (pictured??) you missed out on??
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 08-16-2021, 01:01 PM   #4
Captain X
Captain X's Avatar
Thanks, I might've found what I'm looking for already.
Now if only I could find another pick-up in as good of shape as this one was.
No, I didn't. I'm going to guess 16 inch, though. They were 8-hole rims anyway.
Old 08-16-2021, 07:09 PM   #5
factorystock
factorystock's Avatar
'67 and '68 did come with optional 16.5" 17.5 and 19.5" solid wheels and all these came with clips including the early 16.5". The wheel in your photo appears to be the 17.5". Here is a photo of a 17.5" black and the 19.5" silver, both have the correct clips.
factorystock is offline   Reply With Quote
Old 08-16-2021, 07:15 PM   #6
72c20customcamper
72c20customcamper's Avatar
My 68 has 17s on it
Edit better pics
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-17-2021, 04:32 AM   #7
Captain X
Captain X's Avatar
I don't suppose anyone makes anything like these new, do they?
Old 08-17-2021, 10:27 AM   #8
72c20customcamper
Doubt it. Definitely dont make mine as it's a 3 piece rim . Retainer type split (not a widowmaker)
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-25-2021, 02:56 AM   #9
Captain X
Captain X's Avatar
So I found some 7-17.5 rims. Whereabouts would a guy find some tires that size? All I seem to be able to find are 8-17.5. Would those fit on my rims?
Old 10-25-2021, 06:57 AM   #10
Sure, an 8" tire will fit just right on a 7" rim
Old 11-07-2021, 02:31 PM   #11
Captain X
Captain X's Avatar
Like seriously or are you being sarcastic? I only ask because one of the random tire sites I found when I was looking for 7-17.5 said "You will need to use 8-17.5" link
Old 11-07-2021, 02:43 PM   #12
Bigdually
An 8" wide tire for sure will fit on a 7" wheel, in fact should be just perfect.
Not uncommon at all for guys to run 12.5" wide tires on an 8" wheel. Going up one inch over wheel width is perfect
2.5 Ton Pickup Build:
1989 GMC 6000 Pickup/Toy Conversion
Bigdually is offline   Reply With Quote
Old 11-07-2021, 02:57 PM   #13
HO455
Post Whore
HO455's Avatar
One thing to be aware of with 17.5 rims is that tires are limited to bias ply light truck or if you want radials then they are medium duty truck tires with 14 or more ply side walls. Which on trucks like ours ride like Flintstone wheels. But they will likely outlast the truck.
17.5's are also available in trailer tire construction but those aren't up to the sidewall loading that the front wheels on a vehicle experience.
No good choices really
Those 17.5 x 7"" wheels you have with the hub cap provisions are really rare as most are in the 5 to 6 inch range.
RIP Bob Parks.
Old 11-07-2021, 03:13 PM   #14
HO455
Post Whore
HO455's Avatar
Every tire vendor will tell you what the manufacturer recommended wheel sizes are. The manufacturer recommends sizes to optimize wear, noise reduction, and to limit warranty claims. Millions of tires of tires are mounted and ran outside of those recommended parameters every month without issue. The ricer example below is an extreme example that you see everywhere. No manufacturer would ever recommend or consent to having their product mounted like that.
RIP Bob Parks.
Old 11-07-2021, 03:19 PM   #15
Captain X
Captain X's Avatar
Huh. Kind of strange that I happened across two '67 C20s with this type of rim at two different action sales in my state this summer then. I was stoked that the one I got had them, though to be honest I'm pretty sad I didn't get the first one because its body was in much better shape. But someone had much deeper pockets than mine and must've wanted that one as much as I did. Here's a link if anyone is curious. I will always be salty over that one, because I just can't seem to find a cab besides that one which isn't rotted out in the back corners or the rockers, and doesn't have a hole drilled through the roof for a CB radio antenna.
Anyway, it's a relief that 8-17.5 will work, as I've found a couple of sites that offer them. I was kind of wondering if there might be a modern sized tire that would work that I could ask my local tire shops about, though.
Old 11-07-2021, 06:08 PM   #16
factorystock
Another route would be the 16.5" with clips, the GM issues of '67-'68 are very rare, bottom photo, but the aftermarket issues are more plentiful, but still considered hard to find. The Firestone Transforce radial is available in 9.50X 16.5". Top photo is an aftermarket 16.5" wheel made by Kelsey Hayes. Middle photo is member Layne '68 C20 Custom Camper with Kelsey Hayes 16.5" clip wheels with correct '68 C 20 caps. Bottom photo is rare GM 16.5" wheels with clips
Old 11-12-2021, 10:49 PM   #17
Captain X
Captain X's Avatar
I'll probably stick with these rims. If those 8-17.5 tires will fit, Coker Tire has some, and while I'd love to find tires that would work for less, I'm a big enough fan of these old style rims to get these expensive ones. Of course, the flip side of this is that I only have a couple of good hubcaps for them in that original style. The other two might theoretically work if I was just going to repaint them, as they would need to be pounded out and/or use body-filler to resemble their former selves, but I was really hoping to have them chromed.
Incidentally, anyone happen to know where I could find some kin good shape that aren't like $100 a pop?
Old 11-13-2021, 07:56 AM   #18
factorystock
Tire size on post #5 is 8-17.5 (black rim) and 8-19.5 on silver rim. Both of these rims are 5.25 inch wide. Tire size is correct for rim size, they do not bulge over, but does seem odd for the 2.75" difference. Tire size and diameters were confusing back then, the tire in post#6, the 7.50-17 is much larger than a 8-17.5, the same reason a 7.50-16 is a much larger tire than 8.00-16.5
Old 11-13-2021, 05:22 PM   #19
Captain X
Captain X's Avatar
Oh, I should maybe post some pictures of what I actually have now.
Old 11-14-2021, 01:52 PM   #20
factorystock
Looks like an original spare tire. The 7.00-17.5 6 ply is an obsolete size, thankgod. The 8-.17.5 is the replacement size and is 8 ply. It is available in traction tread also.
Old 11-14-2021, 03:27 PM   #21
DPowers
DPowers's Avatar
I got 17.5 inch tires at Walmart.
DPowers is offline   Reply With Quote
Old 11-14-2021, 03:46 PM   #22
factorystock
These rims look great with nice paint! Those are the modern radials in the 14- 16 ply range. Many Isuzu and Hino 2 ton type trucks use 17.5's.
Old 11-16-2021, 07:42 PM   #23
duallyjams
duallyjams's Avatar
Used the center out of a 17.5 wheel to make 17x8 wheels to keep the correct clip style hub caps.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-17-2021, 05:13 AM   #24
Captain X
Captain X's Avatar
Oh I have all 5 rims - this is what originally came on Lot #39 of this auction.
I am actually kind of semi-tempted to get the traction tread for the back ones since that's what was originally on there, but my dad tells me that it would probably be pretty loud on the highway, so I'll probably stick to just the regular tread all around. It's good to know that 8-17.5 will work on these rims, though, as it looks like Coker Tire has them.
Would this size fit on my rims do you think?
Old 11-18-2021, 03:24 PM   #25
factorystock
Looks great! This is what we have to do if the aftermarket ignores us. The Kelsey Hays wheel in post #16 is in fact a 17.5" factory center installed a wide 16.5" rim and is shown in ad below, but they were done in the 60's and 70's when camper pickups were popular. I've been calling for the need and market for an aftermarket 16" wheel with a 17.5" center ( these will have proper offset) to help out those with '48-'68 3/4 tons, but to no avail. IMO, the period correct hubcap design is essential to the year model look.
