Old 09-01-2021, 11:44 AM   #1
mschwader
Frame Crossmember Replacement '62 C20 Rear End
Hi All! Where can I find replacement crossmembers for the rear of my frame? Original owner used the truck on a farm. Welded a hitch to the crossmembers and whatever he was hauling bent them.
mschwader is offline   Reply With Quote
Old 09-01-2021, 04:59 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Frame Crossmember Replacement '62 C20 Rear End
I highly doubt any aftermarket company is making those, so your best bet would be to source them from a donor, 60-62 frame.
If you become a supporting member of the site, you can post a WTB add over in the parts section of the board.
Another option would be to contact AspenAuto
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-02-2021, 03:59 AM   #3
BabyBlue64
Depends on your situation, but you can also try to heat up the dents in the crossmembers and push the truck with the hitch to something solid. Maybe the crossmembers will come back in original position.
BabyBlue64 is offline   Reply With Quote
